Question about Canon PIXMA iP1500 InkJet Photo Printer
Ink smears I get black ink lines on prints. They go along or across prints from 1/8 to 1/4" long. I have changed both ink cartriges. Do I need to clean something or take it in to be repaired?
    President:
  • 1,073 Answers
You need to clean it inside, use isopropylalcohol witch is good for cleaning ink
Posted on Dec 07, 2008
DESIGNJET 450C SMEARS (BLEEDS) INK
Most likely the media (paper) is touching the print heads. This can occur because 1) the media holding mechanism is not holding the media correctly, and the media buckles, or 2) the carriage to media distance is too small. (Check the adjustment in chapter 5 of the manual).
I found a copy of the procesure online:
HP DesignJet 430 Service Manual Adjusting The Carriage To Media Distance
Dec 21, 2017 | HP DesignJet 450c InkJet Printer
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
140 people viewed this question
old marine
old marine
