Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
LG projection TV model 52SZ8D-UA sound go on and off
When i turn my TV sound go on for 2 second and off .after maybe one hour it is start working fine.
Before I need to wait shorter period of time to get sound but now taking longer and longer
    Genius:
  • 2,920 Answers
Your audio board is going out take it to a shop and have it fixed
Posted on Dec 07, 2008
42LK520-UA LG television horizontal black lines that fill up the entire tv. Video included. Need info on part replacement.
Check and replace the damaged CCFL lamps at the back-light section. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2015 | LG Televison & Video
After connecting the Wii to LG TV (55 inch LD520C) the LG TV will not stay on! it blinks an image 3 times (maybe 10 seconds total), then turns OFF!! we disconnected the Wii, but the LG TV still turn
How old is the TV? LG warranties its TV's for 1 year unless you have a extended warranty from where you got it which is stupid not to have. Was the TV exposed to moisture or bugs? I've never heard of a Wii corrupting a TV. If no warranty then it could be a power supply or the main board. Find a repair service that gives free estimates, find out what needs to be fixed then go online and find the replacement part-Ebay.com and www.shopjimmy.com are good sources for parts. Replacing parts is easy, a screwdriver for screws and unplug cables by hand. If it's a power supply wait 1 hour before removing because the capacitors can still hold a charge and to be safe hold it by the edges of the board and put it on a non conductive surface like glass. If it's the Main board just switch it butsometimes after LG and Samsung main boards are replaced Solarization can happen. If it does just google it and you will find a easy fix. Good Luck
Feb 25, 2014 | LG 42LC2D 42 in. LCD HDTV
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
Does the LG 52sz8d dlp tv light bulb also have a housing?
Yes,its what holds lamp in, Mats has Lamps for $99.00
1-800-628-1118
Sep 25, 2010 | LG 52SX4D 52" HDTV
Can the service menu for the LG 52sz8d dlp tv be accessed from the orig remote not the service remote just installed new lamp and tv was working fine for 1 week now the lamp indicator light comes on and...
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Apr 22, 2010 | LG 52SX4D 52" HDTV
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
270 people viewed this question
Computer Repairing
Computer Repairing
