Question about Maytag Performa PAV2200
Maytag performa washer hot water runs continuously
The washer's hot water continues to run even when the machine is off, I had to turn the water valve off to the washer. The Cold cycle works fine and even when I put it to Cold wash and turn the hot valve on it starts to fill immediately. It doesn't seem to be a water level problem because the washer works fine as long as the hot water is turned off to the machine
  • 1 more comment
  • Anonymous Mar 26, 2014
    gives an e02 fo8 error
  • Anonymous Mar 28, 2014
    cold water works sometimes and sometime on the cold cycle the hot water is used
  • Anonymous Mar 31, 2014
    Hot water runs in good but cold barely runs in. Water supply to washer is fine.
    President:
  • 878 Answers
Dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Posted on Feb 19, 2007
I haveno idea how there continues to be water run inside the washer after the cycle runs through. I have even shut the water off and there seems to be water still running inside,
Turn off your hot and cold water valves. Your water valve inside the washer has gone bad. What happens is the valves open and close there is suppose to be a filter screen on both hot and cold inlets where you connect the water hoses to. If not the debris from the water line gets in there and clogs it up leaving the valve open which is causing your problem. Also seen it where people on well water have this problem a lot because the water might be hard with sediment . You can have a qualified technician come fix it won't be too expensive hope this helps and thank you for using FixYa!
Jan 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Aug 10, 2009 | Maytag Performa PAV2200
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Maytag performa
does the water overflow from the waser. also try and fill the washer up with water and when you feel it should be filled to capacity shut the water off to the washer. and turn off the power. After you have done that turn the water back on and turn the power back on to the washer if the water stops running it could be your water valve and is easily replaced. if the water continues to run it could be the pressure switch (water level switch) or it could be a hole in the pressure switch hose.
Dec 30, 2008 | Maytag Performa PAV2200
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Washing Machines Logo
219 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
