Question about JVC Everio GZ-HD7 Camcorder
Is the jvc gz-hd7u the same as the gz-hd7us? - JVC Everio GZ-HD7 Camcorder
SOURCE: UpDated Firmware for the JVC GZ-HD7U.
no.
no updates
Posted on May 30, 2008
Ciza24
  • 59 Answers
SOURCE: JVC CAMCORDER GZ-HD7U
You CAN NOT use the Firewire to capture your footage like DV or HDV camcorders. I too Have a macbook pro and use FCPS2 to edit my footage. If you want to get the footage off of the HD7u, you'll have to connect via USB2.0 and download the .TOD files and use a program to convert them. I use MPEGStreamclip. It will work with the .TOD files and convert them to a format that iMovie or FInal Cut will understand. If this is not for professional work you'll probably be fine converting the footage to the HDV standard or DV standard and not have to render in FCP to edit the footage.
Caution... MPEG2 codec may be needed. If you have FCP or have Quicktime pro, you probably already have it other wise you can purchase it from apple for $29.99 or if you try real hard (not to hard) you can probably find it on a torrent for free.
I hope this helps your situation
Ciza
Posted on Oct 29, 2008
adnanbhatti
  • 1188 Answers
SOURCE: is there any way to download the set-up disk for my jvc gz-hd7u
Connecting the Camera to the PC
Preparation:
Set the camera’s power/mode switch to OFF.
NOTES
• When the USB cable is connected, turning on or off the camera causes malfunctions of the PC.
• Connect the camera directly to the PC, not through the hub.
• Do not use an extension USB cable.
• Saving the wrong kinds of files in a recording medium or deleting files or folders from a recording medium can cause problems with the operation of the camera. When it is necessary to delete a file from a recording medium, delete it through the camera. Also, do not move or rename folders and files in the medium on PC.
• Never disconnect the USB cable while the access/charge lamp on the camera lights or blinks.
1 Create a folder to back up files into.
2 Set the camera’s power/mode switch to STANDBY/ON.
3 On the camera, move the set lever to
\/ / /\ to select [PLAYBACK ON PC],
then press down.
4 Double-click [EVERIO_HDD] or [EVERIO_SD].
5 Select the folder that you want to back up, and drag & drop it into the folder you created in step 1.
SD_VIDEO:
Folder that contains video files. If you want to back up fi les individually, open this folder, and drag & drop folders such as [PRG001] one by one.
DCIM:
Folder that contains still image fi les. If you want to back up fi les individually, open this folder, and drag & drop files such as [PIC_0001.JPG] one by one.
When you have finished operation
Always follow the procedures below when disconnecting the camera, or turning off the camera/computer power.
Failing to do so may cause damage to the camera and computer.
1) Confirm that the access/charge lamp on the camera does not light or blink. (If the access/charge lamp lights or blinks, wait until it is turned off before proceeding.)
2) Double-click the [Safely Remove Hardware] or [Unplug or Eject Hardware] icon in the status bar.
3) Select [USB Mass Storage Device] or
[USB Disk], and then click [Stop].
4) Click [OK].
5) Disconnect the USB cable.
6) Turn off the camera and PC.
Posted on Sep 20, 2009
SOURCE: Manual for JVC GZ-HD7U
i recorded my video clip vertically! i need to rotate them from the camcorder! how do i do it????
Posted on Sep 22, 2009
SOURCE: no disc for my JVC Everio GZ-HD7U
My Jvc GZ-HD7U will not connect to by PC. I am running Vista. Is there a suggestion?
Posted on Apr 07, 2010
I purchased a mac laptop and it does not recognize my camcorder [jvc GZ-HD7u]. Any easy solution? Thank you David
You might have to install a driver before it will recognize any digital camera.
Jun 26, 2010 | Cameras
No disc for my JVC Everio GZ-HD7U
You don't need the disc. Buy Corel's latest videostudio x2 for editing. To extract the video files from camera just plug into computer with USB cable and search the camera for files.
Jan 01, 2010 | JVC Everio GZ-HD7 Camcorder
Nov 24, 2008 | JVC Everio GZ-HD7 Camcorder
Remote not working
If you have a manual there usually is a master reset for your camera. Otherwise a menu item changed. Lastly I hope it hasn't failed on you.
Sep 12, 2008 | JVC Everio GZ-HD7 Camcorder
DVD Burner discs
uninstall it and reinstall it
lala linda
Aug 24, 2008 | JVC Computers & Internet
There currently are no updates for the camcorder, they discontinued the camcorder shortly after it hit stores.. seemed to have alot of issues.
To the other user with the similar issues. The camcorder isn't the same as a DV camcorder and you may not be able to capture live. My suggestion would be to mount the camera using the USB cable and copying the video files from the camcorders internal hard drive to your desired location.
You may need an application to convert the videos, I suggest MpegStream Clip. They have a version for PC and Mac.
May 21, 2008 | JVC Everio GZ-HD7 Camcorder
JVC Everio GZ-HD7 Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
