My RODE NT2s sound output is intermittent, it is OK then it cuts out. Gently shaking the mic reveals about 3mm of movement of the top assembly/condenser, i suspect that a peice of solder has come loose making an intermittent connection problem.
3 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Pioneer D711
Hi...
Is there an access cover with screws in it underneath?
MOst of the receivers have something like that.
I would also check the output PCB assby for shorts or opens.
Posted on Mar 24, 2009
  • 10 Answers
SOURCE: Denon AVR 1601 with no sound output
The usual problem with this model is the main power supply transformer is open. There is a thermal fuse inside the transformer that is open thats why if wont supply voltage to the power output amplifier. It would turn on because the standby circuit is still functioning.
Posted on Aug 10, 2010
Rode Nt1a Beep Sound
Does the background sound get louder or fainter when you change the mic gain on your mixer? If it depends on your XLR cable, it may be radio interference, and you need to make sure you use top quality shielded cable, and that you're wired "balanced".
Jun 04, 2015 | Rode NT1A Professional Microphone
We have a wirless Microphone using with a xp510i itwas working OK but we think somepne has played with the knobs as I cant get the Mic to working through the speakers any ideas
Process of elimination needed. Plug a corded mic into the wireless channel. Does it also cut in and out? If not then it sounds like the wireless is the one cutting in and out...not unusual for cheap units. Your wireless is not a cheapie? Then check the wireless squelch setting located on the receiver as it may be set too high.
Apr 25, 2014 | Samson Airline 77 Aerobics Wireless...
MY VIDOE CAMCORDER WILL NOT RECORD SOUND WHEN I ATTACH A MIC
You need to connect your mic to an amplifier first and then to camera. Orherwise mic has not enouth power output. Zoom h4n might work but its expansive. Or u can buy wm-v1, wireless mic, it'll work just fine. Or buy mic with power already built in, like Rode VideoMic.
Apr 12, 2012 | Canon VIXIA HF R20 Camcorder
I noticed today that my Rode mic didn't produce any sound at all. It has been on a mic stand for a couple of weeks at my home. I read that moisture can be one reason why the mic doesn't work. I...
The whole situation that you describe makes me believe that the Rode mic is ok. Please double check your cables, the connections and the settings at the mixer that you connect the Rode. Also make sure that the phantom power supply is enabled.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 10, 2011 | Rode NT1A Professional Microphone
My Road NT 1A Microphone is not work In Sometimes. Mic cable is OK But Sound not to came in My Alesis Sound Card the Mic gain is Very hi level Coming sound in Sound Card but it is Very low level, But...
seems like u have a damaged capsule... the damage maybe caused by accumulated moisture or spit that must've got to the capsule... i have the same problem... if ur mic is still under the 10 yr warranty rode will repair it for free
Jan 16, 2011 | Rode NT1A Professional Microphone
Canon printer says error paper output slot
Hello there Ok try this it may work for you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
When recording the signal starts out great but then gets very quiet, sometimes there's a high pitch frequency too. Any ideas? It's 2nd hand but has been working fine for over 3 years.
Your capsule is gone, sorry. I've owned 2 NT2s that I bought over 5 years ago. Eventually the capsule goes and that was what happened to mine: "started working-got quiet-unwanted noise"
The first time it happened Rode replaced my capsule for a $50 flat rate repair fee (capsules are $300..what a great co.)
However I recently contacted them about the second one and they no longer have replacement parts.
They did offer to give me a discount on a new mic if I sent the broken NT2 to them for parts.
It's too bad...I love those mics.
Nov 06, 2009 | Rode NT2 Professional Microphone
Hi, my NT2 has started having massive cuts in volume mid take and also it's generating a very high pitch frequency from time to time. Any ideas? Mike
Oct 27, 2009 | Rode NT2 Professional Microphone
When I switch on my Rode NT1 - A mic - it is OK until I speak into it and it cuts off for about 20 mins. Then it comes on - then it cuts off when I speak or sing. Can you advise?
I had the same issue. The sound would fade and then go dead.. The preamp in the device I was using wasn't strong enough and also the phantom power seemed too low to sustain the microphone. After adding a TUBEPre by PreSonus, all of the issues went away and I was shocked to hear how good this microphone really is. Was the issue low phantom voltage/? or a lousy preamp? All I know is , after adding a preamp all of the problems went away.This has to be the best microphone I have tried in this price range.
Oct 17, 2009 | Rode NT1A Professional Microphone
Rode NT1-A Distortion on "S" sounds and plosives
This is typical component failure. The mic will require professional service. Condenser Microphone Mod Service
Nov 01, 2008 | Rode NT1A Professional Microphone
37 people viewed this question
 Grubhead
Grubhead
