Question about Emerson EWL2005 20 in. LCD Television
Picture too small on screen
Emerson CR202EM8 Picture vertically only stretches about an inch. Horizontally stretchs all the way across the screen. Because the picture is so small i cant even see the text when i go to the menu so i dont know if theres a place in the menu i can go to stretch the screen back to normal size. Thx.
    Habit-Forming:
  • 62 Answers
It's a fairly inexpensive repair but with the low cost of new TVs I recommend junking It.
Posted on Jan 16, 2018
4 Suggested Answers
SOURCE:
SkinWill
  • 148 Answers
SOURCE: EMERSON EWL2005 20" LCD
Impacting the television can cause the video processor to come unmounted to the main board or the LCD panel inside to become disconnected. You need to take it in for repair.
Posted on May 24, 2008
  • 48 Answers
SOURCE: TV screen has 2 different shades horizontally
Probably one of the backlights have faulted
Posted on May 06, 2009
dave1645
  • 834 Answers
SOURCE: I have a 32 inch Emerson tv..model # LC320EM8AN
t-con board is failing have a tech replace it
Posted on Sep 20, 2009
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Screen is stretching on each end. Vizio 32 inch. The picture is stretched on each end. The picture looks real weird and it almost makes you dizzy when you look at it.
Sounds like the display is in a mode which is sometimes called "Horizon", where they seek to fill the entire 16:9 screen with an image which is originally 4:3 by leaving the center of the image mostly alone and stretching the ends out horizontally. If your remote control has an "Aspect" button you might try pushing that a few times to cycle through the various settings.
Oct 10, 2009 | Vizio Televison & Video
My sony tv problem is that the picture is stretch horizontally..
If you have a DVR too, there is a pound (#) button on the beside the zero on the DVR remote that stretches my screen off and on. Try that.
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is stretched on top and bottom of screen
you have a vertical linearity problem. change the vertical output and components.you need a qualified tv technician to solve this problem
Aug 15, 2008 | Emerson EWF2703 27" TV
Screen stretched on JVC AV-28WT5EKS TV
There are some parts that have failed in the horizontal scan amplifier. You will have to have the set serviced by a TV service tech to determine the exact failed parts and have them replaced.
Jerry G.
Jun 27, 2008 | Televison & Video
Picture Stretch on Panasonic PT-53WX54
Usually this is an indication of a failing capacitor in the vertical circuit. Have those been checked? I would look for 100ufd caps in the vertical circuit. Check with the tech.
Dan
Jun 02, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Emerson EWL2005 20 in. LCD Television Logo
224 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
