Question about i-Bulldog BF-150 Digital Media Player
New i-bulldog wont charge!!
Hi there! I have a new i-bulldog MP3 player that wont charge. The battery is dead and I have it plugged into my Mac by USB cord and it isnt doing a thing! Maybe Iam doing something wrong....please help!
5 Suggested Answers
  • 7 Answers
SOURCE: how to load songs in i-Bulldog IMP-90 (256 MB) MP3 Player
Removable disk F. Go to the place you downloaded it too and send to removablle disk.
Posted on Mar 26, 2007
  • 112 Answers
SOURCE: I-Bulldog mp3 player
Try formating the player. Got 2 my computer rightclick on the mp3 icon and choose format. Let me know if this solve the problem
Posted on Aug 15, 2007
  • 12 Answers
SOURCE: i-bulldog mp3 player IMP-90
Send it to an electronics Repair Place so As to not lose the warranty or get a new one Probably loose wiring
Posted on Jan 15, 2008
  • 4 Answers
SOURCE: i-bulldog ib200 2GB mp3 player
most mp3's have similar cords so if you took it into your local electronics store they could probably find you a match.
Posted on Jan 29, 2008
  • 45 Answers
SOURCE: i need a usb cord to put songs on it and off
when my usb cord didn't work anymore i used the cord for a digital camera, a USB A Mini cord to use it more. but then it depends on the type of player. But if thats the case, the cord is available at any electronic store.. i'm canadaian and so easily got it at Wal*Mart
Posted on May 27, 2008
0 characters
1 Points
Battery has gone dead and wont turn on to take charge
If its not getting charged, please change the battery with a new one or you can trick, you can show some heat to the battery, which makes the battery for use of charging. But it wont be useful and effective as it is a work around solution. Please use a new battery and try charging.
Apr 01, 2012 | Sylvania SMPK 8099 Video MP3 Player
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Here's a link:
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
Ipod wont start. No response when plugged to the PC.
this means there is probably a harddrive issue or (less likely) the battery is dead and something prevents the charger from engaging (if this ipod is new than this is not the case) neither of these are easy to fix however both are covered under apple warranty,
If you don't have warranty coverage and want a slightly cheaper repair than the one apple offers this website works well--
Mar 02, 2011 | Apple iPod MA446LL/A MP3 Player
I have two ipod video's a1099 and a1059, They were dead wont turn on wont charg,, I got two new battery's The a1099 came on with new battery and had about 1/2 a charge, charged it last night just...
Hi, answer a little bitlong, you can use this links to reset the ipod.
Hope it helped. await your comment.
Take care.
Jun 06, 2010 | MP3 & Digital Media Players
Dead player
Hello :
According to your description I think that the battery is dead [ can't be recharged anymore ] . You need new battery .
good luck .
please rate !
Mar 31, 2010 | Creative Labs ZEN V Plus MP3 Player
Model#1825 it wont charge or turn on
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . You need new battery . If you replaced the battery with new one and the device still can't be recharged , then I recommend you to take your player to the service .
You may also check the power transformer or power cord .
good luck .
please rate
Mar 30, 2010 | Toymax Impecca MP-1825 MP3 Player
My Fuze wont charge its completely dead i plug it in to charge doesnt do anything it will not charge like its suppose to
Hi, you said it all, its completely dead, i suggest you get a battery booster to boost the battery before charging it, boosting the battery will make the charging more effective.
But if you are not still satisfy with the charging, you can get another new battery, but avoid the battery going completely dead before charging, this reduces life span of battery.
I wish you best of luck.
Jan 09, 2010 | SanDisk Sansa Fuze MP3 Player
My mp3 go gear wont charge, i've tried to charge it on the ubs port and i've tried to synx it again and nothing is charging it
try getting an old usb phone charger and using that if that wont work then your battery may be dead and its time for a new one
Sep 20, 2009 | Philips PSS110/17 MP3 Player
It wont turn on either
your battery is likley to be dead or its broken
i recomend charging it or get a new mp3
Jul 12, 2009 | Philips SA3025/37 Flash MP3 Player
MP3 & Digital Media Players Logo
Top i-Bulldog MP3 & Digital Media Players Experts
Gyula Lacz
Are you an i-Bulldog MP3 and Digital Media Player Expert? Answer questions, earn points and help others
