Question about Yamaha RX-V661 Receiver
Set up of RX-7663 / E-1 Error No Front SP
No matter what settings i use .. when I go to use the auto set (after plugging in the microphone) it goes to the first step .. turning the volumn up in my Left front speaker .. it goes loader and loader and then I get the error .. I hear a speaker .. E-1 says NO FRONT SP CHECK WIRING .. bad microphone?
  • 54 Answers
SOURCE: yamaha rx-v661 unsolved speaker wiring error
1. Try running the auto setup without the sub. ( is it a powered sub {the sub has its own amp on the back} or is a NON powered sub that is driven off the speaker jacks of the Yamaha receiver. )
If the sub is powered, and connected to the Amp via the RCA cable from the " sub out " jack, chances are you either have a defective sub or a gound loop.
Good luck...Rob
Posted on Mar 04, 2008
  • 236 Answers
SOURCE: Rx-v461
but does it sound normal in all other sources?
Posted on Mar 19, 2008
SOURCE: no sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
Posted on Jun 30, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Static noise from Front Left Speaker
It would probably be with the speaker. That is easily checked by simply unhooking the speaker and running the test again.
Posted on Jan 15, 2009
Dipu007
  • 2110 Answers
SOURCE: Receiver is shutting down.....
check the speaker wire that must be broken in between...
Posted on Feb 21, 2009
How do I set phone call volumne on earbuds with microphone & remote control?
I'm the author of the question - I fixed it by yanking out the earbuds, taking a call and reducing the volumne down from max with the earbuds unplugged. After that, I was able to adjust the phone call volume with the earbuds (JVC HAFX32A Marshmallow Earbuds) plugged in.
Jun 25, 2014 | JVC Audio Players & Recorders
Front speakers won't work simultaneously with the rest of my 5.1 system
This is an either-or situation. As your manual explains, SP-A is one set of speakers and SP-B is another separate set. Your Yamaha receiver should have an SP-A + SP-B setting but given the way your speakers are currently configured it's anybody's guess as to what the result will be.
Dec 15, 2013 | Yamaha Rx-v365 A/V Home Theater Receiver
The volumn on my elemnt tv goes to 63,it is very low
Look first to see if a DVD etc connected by itself to a rear input on the set gives you normal sound or not--this will rule some possible things out.
Jun 15, 2012 | Element Televison & Video
Sound
try to replace the (-) volume button it is defective so the volume will auto down..
after you replace that 100% works fine..
Apr 27, 2012 | Audiovox PLV16081 8 in. LCD TV
Auto MCACC Screen Appearing
It would appear the unit thinks your McAAC microphone is inserted. Is it?
Automatically setting up for surround
sound (Auto MCACC)
The Auto MCACC Setup measures the acoustic characteristics of your listening area, taking into account
ambient noise, speaker size and distance, and tests for both channel delay and channel level. After you have set
up the microphone provided with your system, the receiver uses the information from a series of test tones
to optimize the speaker settings and equalization for your particular room.
Make sure you do this before moving on to Playing a source on page 11.
Important
• Make sure the microphone and speakers are not moved during the Auto MCACC Setup.
• Using the Auto MCACC Setup will overwrite any existing settings for the MCACC preset you select.
• Before using the Auto MCACC Setup, the headphones should be disconnected and the iPod
USB, XM or SIRIUS Radio function should not be selected as an input source.
1 Switch on the receiver and your TV.
2 Connect the microphone to the MCACC SETUP MIC
jack on the front panel.
Place the microphone so that it's about ear level at your normal listening position (use a tripod if possible). Make
sure there are no obstacles between the speakers and the microphone.
The Auto MCACC display appears once the microphone is connected.1
Note
1 • You can't use the System Setup menu in either the main or sub zone when the iPod USB, XM or SIRIUS Radio input source is selected. When you set ZONE 2 to ON (page 61), you can't use the System Setup menu.
• If you cancel the Auto MCACC Setup, or leave an error message
etc.
It's all in the manual.
Some background on the process...
http://www.pioneer.eu/eur/products/42/98/tech/AVAmplifierReceiver/AF_MCACC.html
Jan 30, 2011 | Pioneer VSX-1019AHK A/V receiver
ONKYO TX-SR608 I need to have my volumne up over 40 to get any sound and around 55 to listen to my home theatre on 5.1 . Does this sound normal? Also, how can I view the volumne when using Zone 2? I...
Yes it is normal, the 608 is a THX certified receiver, so it goes by THX reference levels.
In theory once you have run the Audyssey auto-setup with the included mic the proper reference level for watching movies will be 82 if the volume number scale is set absolute or 0dB of it is set to THX relative. At this setting the volume should be the same as watching that movie at the theater. I have mine set to power-on at a level of -30dB which corresponds to level 52 on the scale you have it set to. This is a comfortable lowish level, but I turn it up to at least -10dB AKA 72 when watching movies.
Jan 18, 2011 | Onkyo TX-SR608 Receiver
My sound system indiated error E-4
this is a set up error ...
ERROR E-4
Please check MIC position. MIC
should be set in front of YSP.
The optimizer microphone is not placed
in front of this unit.
Make sure that the optimizer microphone
is installed in front of this unit.
Apr 11, 2010 | Yamaha YSP1000 Main / Stereo Speaker
Rx-v1800 with check sp wires problem,narrowed it down to the center channell speaker which is 8ohms the rest of the speakers are 4ohms center speaker checks out fine on other receivers,could the ohm...
So are you saying the error goes away when you disconnect the center speaker and its cables? Sounds like you have one more step to isolate the exact external component: try a different speaker as the center and/or try a different speaker cable.
Did you set the speaker impedance (Page 33 and 117) to 6-ohm min. AND - the manual does actually say "the impedance of each speaker must be 6-ohms or higher" for all BUT the Front speakers.
Mar 23, 2010 | Yamaha RX-V1800
Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Mar 13, 2010 | Yamaha RX-V663 Receiver
Echo Problem
Try one or more steps to reduce echo:
1. In Device Settings, under Mircophone test make sure that 'Auto Adjust Audio' is checked. It automatically sets the audio and reduces echo.
2. Right click in the class window to open up the context menu. Click Settings in the menu. Macromedia Flash Player Settings window opens up. Click on microphone icon and check 'Reduce Echo' option.
3. Uncheck boost in microphone device settings.
4. Use a headset and not desktop speakers.
If a class participant (may be an attendee or a presenter) is experiencing echo then all other class participants are required to make settings at their ends. Preferably, the presenter may transfer control to the attendees one by one and identify the system generating echo.
Jan 16, 2010 | Acer 90.00012.30B Computer Speakers
Yamaha RX-V661 Receiver Logo
749 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
