Question about Asrock P4I45GV R5 Motherboard
When i boot there no display on the monitor - Asrock P4I45GV R5 Motherboard
    Sergeant:
    Champion:
  • 201 Answers
Start by checking your display card, then cpu then ram , try to remove bios batt remove power cable for 3 min then reput batt try on again otherwise can be faulty main board have you tried a other screen
Posted on Dec 07, 2008
How can I fix an "Out of Range" display?
It means that your display card settings are too high for your monitor. Boot your system into safe mode (press F9 as it boots up) and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced->Monitor and you should be able to adjust the vertical frequency down to 60hz or 72hz. If you get the out of range message on boot up then you will need to try out a different screen on your system, boot into Windows, change the settings and then plug in your original monitor.
Feb 09, 2011 | Westinghouse L1975NW Monitor
The system boots normally but does not display on the monitor, what is the way forward
If it boots normally and there is no display on the monitor,it could be
1.Your Display card could have failed or the VGA cable from the display adapter is not connected properly to your monitor- In this case you will see a "no signal" message on your monitor.
2.If the monitor is powered on nothing appears,then your monitor most likely failed.
3.If the monitor's power on led light is not lit,then make sure your monitor is plugged in properly to the power source.
Oct 27, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
How to force external monitor on lap top monitor broken boots on external monitor than switches right to broken monitor tryed f f3 f5 does not work
The issue is the OS boots but is not SET for the external monitor
You can try and use the FN and the monitor key but as a perm thing you cannot do this, just cannot be done its boots on the port for the primary display and that is the way it was built. Now if the F# or F% does not work then the operating system is not set up for the external monitor with the display broken i do not see a solution for this one as a tech,
thanks for the question tho but i want to remain honest and say its not possiable.
please do rate my answer before you leave thanks.
Aug 24, 2010 | Acer Aspire 4520 Notebook PC
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
Input not support, Acer V193w
if the monitor is DVI conencted to PCI card, the computer will not see the monitor, on boot up, only in the Windows mode.
replace the DVI connecting with a VGA connection on the monitor, if there is no VGA connection on the monitor then you need to get a VGA monitor and connect that to theVGA port on the motherboard connector at the rear of the computer.
Apr 28, 2009 | Acer V193w LCD Monitor
When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Mar 28, 2009 | ViewSonic VX2035WM LCD Monitor
My pc hard disc not initialised and no monitor display
kindly check your HDD's IDE if it is properly connected to your motherboard or better yet check your BIOS booting sys. use default booting sys.
Jul 23, 2008 | SanDisk Sansa m230 MP3 Player
Asrock P4I45GV R5 Motherboard Logo
100 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
