Cannot turn off caption
Tried instructions with no luck.
With your cable box turned OFF press the menu button on the box itself (not the remote) it will take you to a hidden menu. Turn off the CC.
Posted on Apr 08, 2009
I can't turn the closed captioning off. I have went to device tv tried turning cc off. It won't turn off
If you are able to turn the closed captioning off with the original TV remote, then I suggest doing it that way. If you want that functionality on your Harmony One, you can use the original remote to teach the Harmony the closed captioning command. To learn commands, do the following:
1. Log in to the Harmony software. 2. On the "Devices" tab, click "Learn IR" next to the icon for your TV. 3. At the bottom of the screen where it says "MyNewCommand," enter the name that you want the command to have, and click "Learn." 4. Follow the on-screen instructions to learn the button. 5. Update your remote.
Jul 26, 2011 | Logitech Harmony One Advanced Universal...
How do you get rid of closed caption?
Depending of what model of TV you have, the option to turn off the Closed Captioning is usually found in the MAIN MENU under the heading of AUDIO OPTIONS.
Look in the AUDIO OPTIONS menu and try to find where it says CAPTION VISION, or CC1, or CC2, or XDS, or TEXT1, or something similar for the display setting, then switch that to OFF.
Otherwise look on your remote control for a button to turn off the Closed Captioning (CC).
It may be a button called DISPLAY, and you just press that repeatedly until DISPLAY OFF appears on the screen.
If you provide the exact MODEL NUMBER for your TV next time in your question, more precise instructions can be provided in order to help you out.
Good luck.
Mar 10, 2011 | Televison & Video
I have a sony bravia,model # kdl42v4100. I can not get the closed caption to turn on. It says its on but does not show on the screen.Other tv's in the house show closed caption so its not the sat....
The owners manual and how-to guides for your tv can be found at the following link:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=KDL42V4100
Just click on OPERATING INSTRUCTIONS to get the online USER'S MANUAL.
Or try this, USER MANUAL found here:
http://www.docs.sony.com/release/KDL40V4100.pdf
See page 38 for the CLOSED CAPTIONING instructions.
Good luck and post back if this helps or if you need further assistance.
Jan 28, 2011 | Sony Televison & Video
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
Can't turn off captions on mitsubishi wd-62528!!
If you have the original remote it is in the Video Button Menu. Then select CC off, Or CC When muted.
This should work for you.
asnowman
Sep 19, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Sylvania Superset II Closed Captioning
is there a cc button on your remote hand unit.if not its in the setup menu .
Mar 25, 2008 | Sylvania 6427TE 27" TV
Closed caption
Have you verified that the programs you're viewing have closed-captioning service? Some programs and stations do not support CC on programs and commercials. The closed captions are accessed on the HD52W56 by pressing Menu > Preferences > Closed Captions on the remote control and following the onscreen instructions. Select CC1(the first choice for caption); this is the format most stations send in. Good luck!
Jan 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
Adjusting
You have the closed caption turned on the set. Since you did not leave a model number, I cannot tell you the procedure on how to turn it off. Sometimes there is a button on the remote marked CC or closed caption, and sometimes it is switched on and off through the on screen menu. Good Luck
Jan 04, 2008 | Televison & Video
I try to put the caption vision CC1, and it does not work
Is it reading or working on some channels? If it is your set is working correctly as not every channel has closed caption available on them. Good Luck
Jul 18, 2007 | Sony KP-43T70 43" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
