Question about Philips 46PP9302 46" Rear Projection Television
Picture size too large
The picture size has gotten bigger and bigger on this TV. By that I mean the picture is now so big that you miss the top, bottom and sides of the screen. For example, when watching the news, the scrolling bar at the bottom is missing. Watching football, the scores are often missing. When I go to set the convergence, the outer rows of crosses is gone. Keith Maxwell
  • Keith Maxwell Feb 23, 2007
    Of course - it has nothing to do with aspect ration. This occurs even in the picture setup mode.
We have the same problem with the same model. We already had the main board replaced. The picture has gotton so bad that you cannot adjust the pixels anymore. Well, you could never get to the pixels that were off the screen because the picture is too big
Posted on Jun 28, 2007
    President:
  • 1,284 Answers
Did you try chaging the aspect ratio in the setup menus yet?
Posted on Feb 23, 2007
  • Kelly Gangestad
    Kelly Gangestad Oct 28, 2013
    Yes I tried that. Forgot to mention it is a 60" Hitachi Ultravision TV
SOURCE:
The picture is too big for the tv and seems to be growing bigger. how to reset picture size
On some remotes there is a button with Aspect/Zoom, try pressing that until you get the desired picture.
Sep 06, 2014 | Sharp Aquos Televison & Video
Tip
Do I use CBR or VBR for my TMPG v4.0 Xpress MPG2 encoding ?
VBR (Constant quality)
Used to make high quality clips no matter the file Compared to VBR (Average bitrate) this mode generates a bigger file but insure the best picture quality control possible.
Encodes using the VBR bitrate control mode, allowing for a smaller final output file size but requiring a longer processing time.
CBR (Constant bitrate)
This is the Usual encode mode for most commercial DVD.
Because the encoding process is streamlined this mode allows a fast encoding but creates relatively big file due to poor optimization. This mode is usable when file size is not a constraint. Encodes using the CBR bitrate control mode, allowing for faster output but without bitrate allocation optimization, resulting in a bigger file size and possible picture quality degradation in scenes with a large amount of motion.
on Jan 19, 2010 | Global Star Software TMPGEnc DVD Author...
THE PICTURE IS WAY TOO LARGE. THE PEOPLE ON THE SCREEN FILL UP THE WHOLE SCREEN. IT USED TO LOOK NORMAL SIZE & ON CHOPPED WE USED TO BE ABLE TO WATCH ALL 4 CHEFS COOKING. NOW ALL WE SEE IS ONE CHE
Ad? Turn off "store" or "display" mode in menu. Look for picture size or "aspect" in menu. Remote should have button for "Size" or something.
Feb 12, 2014 | Vizio Televison & Video
Flat Screen Insignia TV picture too big? How to adjust picture size?
When the picture is too large there are three possible solutions at least.
Starting with the simplest two: There are buttons on the remote controls (cable/satellite and television) that control the picture size. On the cable remote it is usually on the bottom, and it says hd zoom. Press it and it will size the picture down for you. On the television or satellite remote it might say view mode, picture mode, format or aspect.
Now, the more difficult solution if the above doesn't work: The settings might not be right in the cable box/set top box. If the television is a 720p television, make sure the cable box/set top box is set for 720p and not 1080i even though they're the same (yes, yes I know). Also make sure you are not connecting a cable/set top box to the coaxial rf input when you have the capability to connect to a component or hdmi cable. I hope this helps.
Dec 01, 2012 | Televison & Video
Should I get a projector or an lcd TV?
It all depends of your needs. I own a projector and I've decided to purchase it because I wanted a very large picture. I've looked up for lcd TV's in the picture size I wanted and the prices were sky-high. If you're looking for a normal sized (up to 50 inches) I recommend an lcd TV, it will cost you significantly less money than a projector, but if you want bigger size I suggest you to get a projector.
Jul 29, 2012 | Furniture
The picture seems to have gotten bigger and now the tops of their heads are cut off
When this happens you can try the wide/picture format/view mode button on your television's remote control first. If your remote does not have one or if this does not correct the problem check the resolution on the cable box next. If your television displays 720p make sure the cable box is set for 720p, or 1080i if the television supports that resolution. First you have to make sure your tv in on the right input not the tv tuner input. Then use the hdzoom# button on the cable remote. If you have a satellite remote it might say format or aspect or you might have to go into the cable box/satellite receiver menu and choose 1080i crop or 1080i stretch to get the right picture size.
Feb 12, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Picture is too big for screen
Go into the setup menu of the TV, and you'll find a category called DISPLAY or ZOOM. That's where you can change the aspect ratio so that it fits on the screen. You'll probably get a gray band on the top and bottom of the screen due to the re-sizing.
Sep 02, 2007 | Televison & Video
Philips 46PP9302 46" Rear Projection Television Logo
425 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
