Going through ink cartridges too fast
I am getting approx. 20 color pages per cartridge. I am told I should get much more. Is it a printer problem? Or is it an operator problem? I have purchased cartridges from both Office Max and Kmart, only Hp brand. Any ideas?
    Master:
  • 461 Answers
Check the capacity of the ink cartridges (in ml). HP usually has high-yield cartridges which cost more, but have more ink. Also check your printing preferences to see what your quality setting is. Draft quality is fine for most text and saves alot of ink, Normal or High is only needed for photo printing. I believe Normal is the default.
Posted on Dec 07, 2008
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Epson TM-T60 Printer
I have an Canon Pixma Mp 496 can i know how much documents can i print with it in fast mode. and also the capacity of those two cartridges
Well, here's what Canon says. In my experience, you can expect to go through a black cartridge in about 500 sheets of paper, less for the color. Our Canon uses ink quickly. The printing speed is pretty fast for a printerthat is for black-and-white documents around 8.4 ipm and a color document printspeed of about 4.8 ipm. While for 4R size photo print takes about 43 seconds.Canon PIXMA MP496 resolution of 4800 x 1200 dpi for (max). It is said the all-in-one, because already integrated between print, scan and copy. For copies, this printer has a speed of around 7.6 cpm for black and white documents, while for the color is obtained at about 2.6 cpm.
Oct 22, 2010 | Office Equipment & Supplies
New HP F4400 going through ink too fast
It depends what type of things you are printing. If you are printing text, you should be able to print more pages. If you are printing photos, you are using more ink per page. If you use more of one color, you may also run out quicker. You didn't say if you were running out of ink in the black or the color or both cartridges. The black cartridge is rated at 200 pages and the color cartridge is rated at 150 pages. This is based on printing pages that may differ drastically from what you actually print. Here's a web link that explains this in more detail.
http://www.hp.com/pageyield/articles/us/en/IsoInkjetYield.html
Next time you buy a printer, spend a little more and find a printer that has a larger cartridge (check the number of ml (milliliters) in the cartridge). These printers cost a bit more but you will save on the cost of the ink. Cartridges all cost roughly the same regardless of how much ink they have. You can also look at websites that rate each printer cost per black and white and color pages.
Hope this helps. Good luck!
Mar 10, 2010 | HP F4480 All-In-One Printer
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Mar 24, 2009 | Dell 948 All-In-One InkJet Printer
I have been given a psc 1310, without an instruction manual and without any ink cartridges.The diagram inside the machine shows 5 different numbered cartridges which the machine uses, 27,28,56,57 and 58. I...
Hello.
HP 27 - Black Ink (approx 220 pages)
HP 28 - Color Ink (approx 190 pages)
HP 56 - Black Ink (approx 450 pages)
HP 57 - Color Ink (approx 400 pages)
HP 58 - Photo Ink Cartridge (approx 140 4x6 photo prints)
Hope that helps!
Jun 07, 2008 | HP Office Equipment & Supplies
Printer will not print in Black at all
Had a similar problem.
It turned out to be poor quality ink refills that I bought at the local mall. Found a good ink supplier who charges $4.00 per cartridge.
Try removing the ink cartridge and cleaning with warm water or a little alcohol and a clean soft cloth or swab in the area where the cartridge is seated
Nov 27, 2007 | Epson Stylus 880 InkJet Color Printer
120 people viewed this question
k24674
jasbo
jasbo
