Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
When i replaced the ink cartage for the printer i get the message 'Open Door insert new cartage and close door' once i did this then system ask me 'Did you replace cartage press 1 for yes and 2 for no' i respond 1 for yes. Then system comes up and says 'Theres no cartage'. Has anyone had this problem berfore? Please Help!
  • lbrownmarkus Dec 08, 2008
    THe CYAN ink cartridge said it was empty, so I replaced it. Now, no matter what I do the printer says "No Cartridge CYAN" I've put the old one back in (which I believe still has quite a bit of ink left) and it says the same thing, so I switched it back to the new cartridge. Any help on this? Thank you, L
  • Anonymous Feb 13, 2009
    ive had this problem with cyan, it keeps repeating either no ink or no cartridge more commonly no cartridge, and it will not respond to a command to clean....i have put cartridge in, taken all out put all back in and still it repeats, no cartridge ink empty.
  • 26 Answers
You might have goeetn a bad cartridge. The way the MFC-440 (and lots of other inkjets) detect ink level is by shining a tiny light through a window on each cartridge. If the light passes through then the printer assumes the cartridge is empty.
To fool the printer, take a tiny piece of electrical tape or paper and stuff it into the window on the cartridge. I prefer tape so it doesn't come off inside the printer. Now, the printer will assume the ink is full and should allow you to print with the remaining colors.
The bottom line is, if this works then it means the cartridge is probably empty.
Posted on Sep 29, 2014
  • 679 Answers
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
Why can't I insert ink cartage in slot?
please open the door of printer and push the cartridge slowly and then the cartridge push down, the cartridge come out.repeat this same process to insert new ink cartridge.
Oct 01, 2015 | HP Deskjet 2540 Inkjet Multifunction...
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
Epson nx105 has new black cartridge but cyan out. we just want to print black ink but it will not print at all b/c one is low. any suggestions?
you can change the setting in the printer prefaces or do what i did keep an empty color cartage in the color slot and a good black cartage in its slot.
Dec 29, 2009 | Epson Stylus NX105 All-In-One Printer
Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Nov 01, 2009 | Brother MFC 420CN All-In-One InkJet...
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
Printer
you need always enough ink to keep this type of machine alive (printing fax, copy, scan). you have to replace the empty cart.
Feb 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink cartage replacement
could you please give us the brand name and model no.?
Nov 13, 2007 | Office Equipment & Supplies
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
168 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
