Question about Breville RC19XL 10-Cup Rice Cooker
Cook light not on
When we press down on the button, the cook light does not come on....when we lift the rice dish out, it rings.
How to make rice
Cover with the lid and turn the heat down to its lowest setting. Leave it alone - once the lid is on, set the timer and go away! If you lift the lid and let the steam out you can slow down the cooking process, and rice should always be cooked as briefly as possible. Give white rice 15 minutes and brown rice 40 and use a timer - overcooking is what spoils rice. The best way to test if it is cooked is simply to bite a grain. Another way is to tilt the pan and, if liquid collects at the edge, it will need a couple more minutes' cooking.
May 31, 2014 | Emerson Microwave Ovens
How do I turn it on? I pressed brown rice and it is not cooking.
First you need to power it ON then select/press the brown rice button. if still no lights are on, then you need to call the warranty support number.
Jun 22, 2010 | Aroma ARC837 20Cup Rice Cooker
My rice cooker, its not responding. Panasonic SR G06. power is ok , but its just dont want to cook! why??
check replace the micro switch of your rice cooker it is the switch that is connected to the cook and warm button....check for the heating ellement it is the coil that heats to do this open the bottom cover of your rice cooker you can see a round shape fillament examin whether this fillament is not brocken and is connected to the power source
May 20, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Jan 09, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
Tiger rice cooker (model JAT-A55U): Rice is not completely cooked
This one has several options to cook different types of rice, white rice, brown rice, sweet rice.... Press the menu to see the correct setting you need for what type of rice you are cooking before pressing the cook button.
Sep 02, 2009 | Tiger JAT-A55U 3-Cup Rice Cooker
MY RD5081 RICE COOKER ONLY WILL JUST WARM RICE, WON'T COOK.
The preassure switch may be not working right.
It may be corroded, etc.
Unplug the unit and push it back several times, try to see if the spring is working, etc.
Apr 02, 2009 | Hitachi RD5086P 8.3-Cup Rice Cooker
Rice Cooker will not work
On the outside of the rice cooker you should locate a button. Push this down and when rice is cooked, the button should pop up (may or may not ring when finished). Once you see the button pop up (or hear it ring), you should leave the lid on for approx 15 minutes longer to finish steaming.
Dec 27, 2008 | Continental Manufacturing Company CE23201...
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Oct 21, 2008 | Zojirushi NRC-15 8-Cup Rice Cooker
Sticking of cooked rice inside pan
Buy a rice cooker with non-stick inner pot.
Dec 04, 2006 | Panasonic SR-3NA 1.5-Cup Rice Cooker
Breville RC19XL 10-Cup Rice Cooker Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
