Question about Mitsubishi WS-55413 55" Rear Projection HDTV-Ready Television
Cold room can you put a mitsubishi rear projection tv in a room with no heat
  • 55 Answers
Yes. The worst thing for electronics is Heat, it probably won't work better but it won't have any problems.
Posted on Dec 07, 2008
Mitsubishi vs-50609 need to get back off to put in room
Its a one piece screwed and glued cabinet that cannot be taken apart.
May 30, 2012 | Mitsubishi VS-50609 50" Rear Projection...
THE GREEN LIGHT IS BLINKING ALL THE TIME
You have the one that the capacitors go bad on, this set is the most complicated set to work on call the pro's but expect as heafty bill, the chassis has to be pulled out and sent into Mitsubishi for a rebuild.
Sep 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Picture appears concave and shrunken and pulses in size
Replace Both of your STK convergence ICs STK392-570 If this is not number on your s use what it has on them. you can call MATs 1-800-628-1118 o Main STK is what is going bad when IC goes out all together TV will shut down and will not come on. So replace BOTH STKs ASAP! you will also need Heat sink compound to put on back of New ICs.
Aug 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi TV air flow
open the back of the television to check for dust buildup on the heat fins and other components. As well as the fan.
Mar 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
57" DLP Mitsubishi
It is possible that either the heat sensor or the protection circuitry has a problem. The protection circuits will always err on the side of caution. If the fan is good, I'd be looking for the sensor. Can you update this with the model number please? I can check for more details once I have that info.
Thanks,
Dan
May 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WS-55413 55" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
