Question about Innovage 69420210126 Phone
I need to know how to change the volume on the Innovage LCD phone
I need to use the speaker phone but I can hardly hear the person on the other end of the line. How do you adjust the volume on this phone.
Just push delete while using to shuffle through volume levels. Chances are it's just a bad phone and is already on top volume (level 4).
Posted on Feb 08, 2009
Speaker too low, hard to hear. can i adjust volume?
What phone do you have?
On most phones there are buttons on the side to adjust volume.
There are also options for volume in your device's settings, under sound.
If it is hard to hear someone during a call you can turn on speaker mode which will make the sound a lot louder.
Oct 16, 2015 | Cell Phones
How can I adjust the volume I can hardly hear person on other end
Does your phone not have an external volume rocker or volume buttons? You should also be able to adjust the volume from within the Android OS under "sounds".
If the volume is already at its max and you are still having difficulty, it may just be that your handset doesn't have a terribly good speaker in it, and there is nothing that can be done :(
Oct 17, 2014 | Net10 HUAWEI H866C ASCEND Y ANDROID 3G...
No sound can't hear on phone and no ring on phone
Hi Wilma,Remove the cell's battery and then reload it again.Check user profile settings and make sure 'Silent's not the selected option.Select 'General' and then customize the settings increasing tone volumes.Make a call and after the person on the other end receives it,press on the ^ up navigation key to adjust the speaker volume.Problem solved?If not,your phone's speaker may need repair or possible changing.Have it fixed in a repair shop.
Hope this helps.Thanks!Please rate this answer.
Dec 13, 2011 | LG Cell Phones
I have a Shift 3 lcd touch panel phone with 12 digit calculator.I cannot find the manual for this phone.I can receive calls but cannot call out.A manual would be helpful Thanks
  • Check your phone to make sure it is set up properly. Open the back of the phone by pressing your fingertip on the small lever that opens the battery area. The battery cover will come off in your hand. Insert three "AAA" batteries into the back of the phone so you can use the night light feature. Replace the battery cover by sliding it into the battery area and clicking it into place with your fingers. Connect the phone to the telephone phone jack by connecting one end of the wire to the phone and another end to the wall jack. Connect the handset to the phone by inserting the end of one end of the curly phone wire to the handset and the other end into the side of the phone. Listen to the dial tone by pressing the speakerphone or picking up the handset to make sure your Innovage LCD touch panel phone is connected.
  • 2
    Review calls you missed. Use the up and down arrows on the Innovage LCD touch panel phone to view the caller ID phone numbers.
  • 3
    Use the night light to view the Innovage LCD touch panel in the dark. Slide the switch on the front of the panel to turn the night light function on. Slide the switch to the off position to turn the night life off.
  • 4
    Adjust the volume on your speaker by selecting the speaker loudness that you want. Press the hands free button once and press the "Delete" button. Choose a loudness from one to four.
  • 5
    Press the hold button on the front of your Innovage LCD touch panel phone. This will activate the hold function when you are on a call and it will allow music to play while someone is on hold. The hold music is built in to the phone and will automatically play when you press hold.
  • 6
    Save a phone number as a VIP number on your Innovage LCD touch panel phone. Press set and save when an important number comes onto your caller identification. This makes it harder to delete the phone number by accident.
  • Read more: Innovage LCD Touch Panel Phone Instructions ' eHow.com http://www.ehow.com/how_7256783_innovage-touch-panel-phone-instructions.html#ixzz1eMIaaXLV
    Sep 23, 2011 | Innovage Speaker/Caller ID* LCD Touch...
    Volume on speaker phone is too low to hear. How do I increase the volume?
    Afternoon, again I refer to the troubleshooting section of the manual. Another way to find out is to phone the store. As a last resort I go on line.
    Jun 19, 2010 | Innovage Speaker/Caller ID* LCD Touch...
    Speaker phone problem
    It is possible. I have ATT 945(?) 4 line phones that communicate via a DSL-like signal between units to do special things like intercom, etc.
    What I have in my setup is that I have a seperate line from the point of entry of my phone line to my DSL modem.
    I then have TWO stacked DSL filters PER LINE that feed the main phone line running to all the phones.
    Be AWARE that when using the speaker phone there is a modulation of the gains both directions. When you talk OR have a noisy background noise, the gain of the speaker is cut down to prevent feedback. And when you go silent, the speaker gain is increased for you to hear the other side of the call. Essentially it takes as much discipline as the old two-way radios... one talker at a time with these speaker phones AND very little background noise.
    Jan 09, 2010 | RCA 25425RE1 Phone
    Volume on the phone/speaker/ring is very low
    You can change ring tones by pressing the flash button until you get the ring you want. When you get the ring you want press the set button.
    May 24, 2009 | Innovage Speaker/Caller ID* LCD Touch...
    Volume control
    the ear piece may be dead or if its a flip phone check the flex cable
    Nov 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
    Cannot hear the dial tone or the person on the other end
    Your speaker could be going out.  When making a call press the $ button to activate the speaker.  See if that function works.
    Adjust the volume with the volume control on the right  side of the as needed.
    Oct 25, 2008 | AT&T Blackberry Curve 8300 Smartphone
    Have no volume in ear piece to hard to hear
    replaced the speaker in the ear piece this will correct the problem
    Jun 05, 2008 | Motorola Mobility RAZR V3
    Innovage 69420210126 Phone Logo
    100 people viewed this question
    Top Innovage Lands Phones Experts
    wiccan8thhouse
    wiccan8thhouse
    Computer Repairing
    Computer Repairing
    george  peters
    george peters
    Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
