Question about Carrier 38CKC036 Air Conditioner
Carrier 58mvp furnace ecm motor is making viberating noises
Hi: I have a 4 year old carrier weather-maker infinity model 58mvp 060-14 furnace and in the past 2 weeks the ecm motor is sounding noisy and is veberating slightly when it is running. This is a new noise this heating season and since I have about 6 months of the five year total coverage warranty left on it, I'm wondering if this is a common problem and should I call for service? I know It is not the main blower motor itself that is making the noise because I have taken the front cover off the furnace and can feel the ecm motor viberating and the noise I hear is not there when the ecm is not running.
Thanks in advance for your advice.
Ron
  • Anonymous Mar 30, 2009
    I have the same model furnace and it has worked perfectly for the past 17 years when it was installed. Recently the igniter had to be replaced and then I noticed a rattling or vibrating noise when the motor is running at higher rpm's (when the heat is coming up in the morning).
    Novelist:
  • 124 Answers
Ecms are pretty reliable and electronic failure is much more common than bearing or bushing wearout. i suspect the fins on the blower may be coming loose from their pressed on spline and that will start a vibration or shimmy or you could have thrown a weight that balanced the wheel . best to use to warranty to get a new wheel. good luck
Posted on Dec 07, 2008
What could cause carrier fault code 42 besides bad inducer
Could be several causes.
1. Blockage on piping
2. Water in inducer housing slowing down inducer impeller
3. Condensate trap for furnace clogged up.
4. Inducer motor going bad.
5. Leak in vacuum hoses or not connected.
Welcome To the Best HVAC
Oct 09, 2014 | Carrier Comfort 13 Series 1.5 ton 14.5...
Blower motor
Make sure the capacitor matches with the new motor
Dec 09, 2013 | Weather King 10AJA6001AH Air Conditioner
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Does not find furnace
Make sure all wires are hooked correctly ABCD should match. The Kill all power try again. When Infinity control is hooked up correctly it by passes all dip switch so that it can communicate with the tsta furnace and outsid unit. Rus
Apr 30, 2009 | Heating & Cooling
Knock Noise When Carrier Furance Starts Up
have the ac company check the actual blower wheel itself it may be slowly coming apart
Apr 20, 2009 | Carrier Heating & Cooling
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 58MVP; Blower on, no heat. Themosta at 75, temp at 69 and furnace still does not come on. Fault code 12
A code 12 is "Blower on after power-up" Try resetting the furnace with either the Emergency switch or circuit breaker. If it continues, you may need a new control board.
Nov 28, 2008 | Carrier Heating & Cooling
Ignition failure
THE AUTOMATIC IGNITION IS TIMMING OUT BECAUSE IT WILL NOT LIGHT PROBABLY A BAD THERMOCOUPLER TRY TO LIGHT IT MANUALY
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC036 Air Conditioner Logo
2,012 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
