Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Washer problems at first the washer would turn off 3-6 times during a wash. now the washer will not work at all, but the dryer works fine. the washer light inside does not even work, it's like there is no power going to the washer. please any sugestions
    President:
  • 878 Answers
Mardokenly, start with the door lock assy. It looks like power has to go through the wax motor assy (door lock)then the light before getting to the main control board. With the power off and harness removed from the door lock mechanism it should ohm out at 950 to 1100 ohms at room temp. If this passes the test another area to look would be the timer and control board. If the control board does not see a change in timer inputs after 5 minutes of power to it, it will shut the washer off. Things to check would be loose connections at the timer and control board. They have had a lot of service bullitins and service flashes out on this model. One of which has to do with the loss of the nuetral line from the power cord to the control board. When this happens, of course the washer will shut off. You may want to call Maytag and see if you are covered under these service bullitins. Catriver..post back.
Posted on Feb 19, 2007
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
Won't turn on
Press and hold the lock button for 3 seconds - should unlock the control panel
Dec 24, 2013 | Whirlpool Duet WFW96HEA 4.3 cu. ft. Front...
Our washer dryer model GLEH1642FSO will not
sounds like the motor needs new bushes, same thing happened to me last yr, regards paul
Feb 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
May 25, 2008 | Malber WD1000 Front Load Washer/Dryer
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
