Question about Polaroid PDV-0700 Portable DVD Player
I'm having a problem similar to those describe regarding the drop off of the picture during dvd playback. However I noitced that if I plug the player in directly, rather then just running it on the battery, it works fine. My question is this; Has anyone else mentioned this aspect of the problem and if so will replacing the battery fix it?" Right now I have the player on with no disc in it because I thought it might be OVER charged. Any help would be appreciated.
    Master:
  • 416 Answers
The problem of Polaroid DVD-players is too suggen cuttofs during playback. Usually there is no "low battery" warning 5 minutes before it just cuttofs. Usually it has 4 hours playback time.
Probably you need to replace the battery.
More information you can read here.
Good Luck
http://reviews.cnet.com/portable-dvd-players/polaroid-pdv-0700/4505-6498_7-30602915.html
Posted on Dec 07, 2008
Jumping picture on playback on TV DVD player
Try using another brand of DVDR (cheap ones tends to cause porblems in regular DVD players) and burn at a slower speed.
Nov 24, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Picture "freeze up" during playback
your laser lens is probly dirty ;/ just use a qtips and alcool and gently clean the lens if it not work proper ly may be your laser assembly going out...
hope that will help you....
Apr 20, 2010 | Toshiba SD-3750 DVD Player
During playback picture freezes
it's having trouble reading the disk. clean it. use a disc cleaner from walmart or radio shack to clean off the optical lens, too..
Dec 14, 2009 | Televison & Video
DVD playback color is very red
plug red yellow and white cords in all the way
Jan 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Seeing picture on monitor of dvd player
I have the 7 inch monitor but my manual says: "If you feel bright unsuitable during playback, press MONITOR button to select bright adjustment and press + or - buttons until moderate bright is available." If that doesn't work you may have stumbled on the reason the company is no longer in business. They sold crappy stuff.
Dec 25, 2007 | Mintek MDP-1770 Portable DVD Player
DVD Freezes during playback
it might be that you are playing a dual layer dvd in the player. The player needs to focus on the second layer of the movie, and that might be why the dvd freezes. Leave it there for a while and the dvd should continue if it is this situation.
Dec 08, 2007 | Sony AVD-C70ES DVD Player
Samsing DVD-M101
Many commercial films are written to what's known as dual-layer DVD discs, which are like two DVDs sandwiched together. Movie studios try to pack as much cool stuff as they can onto a DVD, so by the time you add movie trailers, documentaries, and other special features, the amount of space necessary far exceeds the 4.7GB capacity of a regular DVD disc. Using a dual-layer disc expands the capacity to 9.4GB, which is enough to hold the movie and many extras, depending on how long the film is. What you seem to be experiencing is a problem related to the DVD player changing layers (when it must adjust the focus of the laser to read the second layer of the disc), which is usually indicated by a brief pause during playback. In the early days of DVD, many players had difficulty during the layer change, which could cause the DVD player to lock up during playback. In other cases, a badly formatted or damaged disc could be the culprit, so you should check the condition of the DVDs that are giving you problems. Since you mentioned that sometimes they work, your problem could stem from a scratch or a fingerprint. But, if the condition of the DVD is flawless, you may have to consider getting your DVD player repaired, replaced, or exchanged (since you mentioned it was new). Since it is a portable DVD player, you may want to try running the DVD player when it is plugged into an AC receptacle. This will at least rule out any relationship to the battery, though a remote possibility. But, portable devices do strange things when its battery is low. Many commercial films are written to what's known as dual-layer DVD discs, which are like two DVDs sandwiched together. Movie studios try to pack as much cool stuff as they can onto a DVD, so by the time you add movie trailers, documentaries, and other special features, the amount of space necessary far exceeds the 4.7GB capacity of a regular DVD disc. Using a dual-layer disc expands the capacity to 9.4GB, which is enough to hold the movie and many extras, depending on how long the film is. What you seem to be experiencing is a problem related to the DVD player changing layers (when it must adjust the focus of the laser to read the second layer of the disc), which is usually indicated by a brief pause during playback. In the early days of DVD, many players had difficulty during the layer change, which could cause the DVD player to lock up during playback. In other cases, a badly formatted or damaged disc could be the culprit, so you should check the condition of the DVDs that are giving you problems. Since you mentioned that sometimes they work, your problem could stem from a scratch or a fingerprint. But, if the condition of the DVD is flawless, you may have to consider getting your DVD player repaired, replaced, or exchanged (since you mentioned it was new). Since it is a portable DVD player, you may want to try running the DVD player when it is plugged into an AC receptacle. This will at least rule out any relationship to the battery, though a remote possibility. But, portable devices do strange things when its battery is low.
Jun 29, 2006 | Samsung DVD-M101 DVD Player
DVD Player makes a slight "tick,tick" sound during playback
I would certainly take the unit back cause that noise could be the tracking or focus coils making that noise as they are being overdriver. This could cause the unit to fail prematurly. Its not an adjustment that you can do your self, it takes special equipment and disc
Jun 01, 2006 | Panasonic DVD-S29 DVD Player
Polaroid PDV-0700 Portable DVD Player Logo
112 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
