Question about IBM Wheelwriter 30 Typewriter
Wheelwriter 5 --cant set the right margin
When I type across the page , I get a single beep where the Right margin would be.
However, the print head keeps moving as you type and does'nt return unless you hit the return key
I pressed the r margin key to reset it but I still have the same problem
  • 478 Answers
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Posted on Dec 08, 2008
Unable to set right margen
The typewriter will type thru the right margin it simply beeps when you get near it
Jan 01, 2015 | IBM Lexmark Personal Wheelwriter 2...
My ibm wheelwriter beeps 1 time when i tab
Does anything else work? It is possible your right margin is set to close to the left margin. Try tabbing all the way to the right, set the right margin, hit the return and then hit the tab. If it beeps and goes all the way to the right, try setting some tab stops and retry the test.
Jan 06, 2014 | IBM Office Equipment & Supplies
When typing a card the left margin is okay but when I continue to type across the card it stops and I can't get it to go any further. Is their a way to change the right margin since no matter what I do it...
First spray some WD40 on the silver shaft that the carrier slides on. The with the machine off slide the carrier back and forth it should move freely if not look for debris inside the T/W.
you should be able to type thru the R. margin it only beeps.
DickyO
Feb 08, 2011 | Lexmark Wheelwriter 35 Series II...
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
Right margin
Hi:
On all IBM Wheelwriters the right margin can always be typed through. The only indication you will get when you reach the right margin is a beep tone. To set the right margin, space to the desired point and depress the right margin key once.
Andrew
Jul 16, 2009 | IBM Wheelwriter 30 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Beeping problem
I would suspect that the right margin is set at that spot.
try moving the printhead to where you would like the right margin to be set, or all the way to the right if you don't need a r. mar., and hit 'R MAR'.
Nov 10, 2008 | IBM Wheelwriter 30 Typewriter
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Right Margin
First with the T/W off move carrier back and forth checking for binds or anything binding the carrier if there are no forgien objects try a little WD40 on the shaft that the carrier slides on. DickyO
Oct 14, 2008 | IBM Wheelwriter 30 Typewriter
Margin Problems
You are in auto return. Press code and R
This should doit
DickyO
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
123 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
