Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
WFD 2460 will not start wash cycle after it has filled with water
The machine will not start a wash cycle once the drum has filled with water, also the machine will not do a spin cycle it starts to drain the drum and clicks as if to activate drum to start spinning but doesnt and continues to drain untill you stop it.It is as if a switch isnt activating in order to start the drum motor. Any ideas would be most welcome.Cheers Mark
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Posted on Dec 07, 2008
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
My bosch wfd 2460 won't spin and drain
Needs to drain 1st then spins after this if not draining .Clean filter take out small hose next to filter to assist in removing water 1st if drum quite full ..Then clean filter this should cure,,,
Nov 16, 2009 | Washing Machines
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Inner drum of my 7 year old washer WFD 2460 rattles on spin and seems unsupported. The rubber surround is intact, is it the only means to support the drum? Thanks. J.Reeve
Hi there!
I would say it is the rear drum bearing which needs replacement. This is what supports the load of the entire drum. The seal is just a water seal.
The good news is that it's a bosch, and replacements are easily available. You are lucky to get 7 years use without problems. Cheaper models give up after 12 months!
Check online for spares under the model number, or have it replacd by a local technician. It is the main drum bearing you need.
If this assists to a solution, Please take a moment to rate as fixya! Thanks.
Jun 18, 2008 | Bosch Washing Machines
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
637 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
