Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
My modern maid double oven is still locked after the self cleaning turned off and the oven is now at room temp.
  • xxvonniexx Dec 27, 2008
    my lower oven locking mechanism (arm) won't release to open the lower ocven door after cleaning. Anyone have a solution?
  • 35 Answers
SOURCE: Oven door locked
you would have to remove oven.remove top panel and disengage latch assembly if you are a tech.
Posted on Jun 25, 2007
watugot
  • 290 Answers
SOURCE: Kenmore oven locked after celf cleaning
Try putting it back into clean mode and and listen for the lock motor to start turning. If you can hear it, keep trying the door until it opens. Don't hold steady pressure on the latch, just pull a little then let off. After you get it open, hold in on the door switch and cancel the clean mode and it should go back to correct position.
If this doesn't work, you may have a failed door latch, control, temp sensor, or switch. Post back with the complete model number and I will look it up and see which latch assembly you have and see if we can get it unlocked manually.
Posted on Oct 21, 2007
  • 106 Answers
SOURCE: oven door won't unlock after self clean
Try unplugging it. If that does not work, try to use a flat object like a butter knife, to move the latch (between handle, and top of stove.) Other than that... have a handy guy you know come look at it....
Posted on Jun 04, 2009
praky16
  • 744 Answers
SOURCE: oven door locked E1 F5
hi..
The manual says F5 means "failed circuit in control". This means that the control panel is burned out.. So just replace this..
Thank u
rate me!!
Posted on Jul 25, 2009
  • 220 Answers
SOURCE: My Kenmore Warm and Ready drawer self cleaning
Hit cancel or kill the power at the electrical/breaker box.
Posted on Sep 03, 2009
Oven won't turn on, self clean lite flashes, replaced control board and checked door switch (ok) nothing
Check the oven door lock assembly for a bad microswitch, there are likely two switches and a motor operated cam that the machine uses to 'feel' whether the door is locked or not when you choose self-clean, if one switch or the other (or both) are not working or the cam is not aligned properly, the unit will be stuck, and will not work as a safety feature... The temp. sensor is also involved and should be tested for 1080 ohms at room temp. (70 F)
Apr 24, 2016 | Ovens
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
I have a modern maid double wall oven (gas). I set it to clean last night (at 3:00AM). It is now 12:PM the next day and it can't unlock it. What should I do?
Try turning the main power off to the house for 5 mins and turn it back on see if that reset your oven.
Jan 01, 2015 | Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
How do you clean an oven with the clean control knob. We have a modern maid
Generally, there is a latch which closes the door on some units...on others it is electrically actuated.  Turn the controls to clean.  Generally, there is a function control and a temperature control which must be activated.  This will latch the door electrically.  A two hour cycle is about right for most soil, if you're given a choice.  Ventilate the area...it smells!  The door will unlatch about half an hour or more after the cleaning stops.
Nov 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Feb 18, 2008 | Ovens
Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Powerman
Oct 20, 2007 | GE Profile JTP56 Electric Double Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
88 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
