Question about Technics Audio Players & Recorders
Re my Technics CD Changer SL - MC3: This unit has provided yeoman service for many years without problem but now has started to act up. After about 45 to 60 minutes of playing on full random mode, discs start skipping. It doesnèt seem to matter which disc is in place. I have cleaned the lense with one of the CD-type cleaners to no apparent improvement. Any ideas. If I have tolet the unit die a graceful death, do you have any suggestions for a replacement Many thanks Gerry Lisk
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your concern could be a failing laser eye. Considering the years of service and the cost of repair plus the downtime, it may really be to your advantage to consider a replacement. Since You have had good experience with Technics, might as well select from the latest models.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 07, 2008
  • Louie  Role
    Louie Role Dec 07, 2008
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track. Please refer to the image i have attached.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Genius:
  • 1,239 Answers
HI
I've seen many times before where the spindle table ( the piece that the CD
rests on and spins) will move. If the voltage to the focus coil of the
laser ***'y is greater than 1 volt then this may be the case. Moving the
table will change this voltage.
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    Quite possible that routine maintenance would cure the skipping problem.
     re-lubing the gears and slider surfaces, a bit of
    light oil at the spindle shaft, etc.
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
    President:
  • 2,110 Answers
Your Lens might have some problem...So it is better to replace the lens with a new one...
    Genius:
  • 2,920 Answers
Clean the lens with a q tip and alcohol. those disk cleaners are junk. it should help take care of the problem and it should allow your cds to play again. dont give up hope yet... ron
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Troubleshooting cd player
Your Optical Pickup is worn out. When you put the disc in the drawer, it must load to read the TOC(table of contents). If it can't read the TOC, it will stop or eject.
Aug 17, 2014 | Technics SL-MC3 61-Disc CD Changer
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
Missing remote for Technicis Model SL-MC59 Cd changer
You will need to go online to Technics and contact customer support and the technical department to see if they can help.
Apr 05, 2012 | Technics SL-MC4 61-Disc CD Changer
Need to replace lost remote for a Technics SL-MC3 Compact Disc Changer
So do I. You can program a universal to do some functions. Get the codes online if you need them. <div><br /></div>
Feb 02, 2010 | Technics Audio Players & Recorders
I have a technics sl-pd887 5disk changer that
I contacted a friend who operates a sterio shop and was convinced that fifteen years of bouncing up and down has made the laser unable to focus and read the info on the disks and the solution is to buy another one . Thanks for you're interest.
Nov 20, 2009 | Technics SL-PD887 5-Disc CD Changer
69 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
