Question about Corel Paint Shop Pro Photo X2 Full Version for PC (PSPPX2ENPC)
Trouble with installation
I am trying to install Paint ShopPro Photo X2 (education edition). It goes throught the full intallation process to where it says "Starting Services" then I get an error message [ (ERROR 1920) Service ProexisLicenseing failed to start. Verify that you have sufficient privilages to start system services] and I cannot proceed. This is on my home computer and I am the only user.
    Genius:
  • 2,920 Answers
Try installing it as an adobe application if possible.it may allow it to run from there
Posted on Dec 07, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suggest to redo the installation but prior to this pls disable:
  • antivirus; and/or
  • the firewall.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
When I load paint shoppro x2 it closes worked fine
try to clean your registry or try to reinstall the software it may have some corrupted files
May 06, 2010 | Corel Paint Shop Pro Photo X2 Full Version...
Trying to install on new computer
On CD or back of packaging. If you registered it, e-mail or call the company. They will accomodate you.
Apr 20, 2010 | Corel Paint Shop Pro Photo X2
My Paint Shop Pro Photo X2 suddenly started to fail to start completely today. I tried updating my drivers, scanned for viruses, and even bought an upgrade to the latest version. When I start the...
I have had the same issue on my Vista machine.
I've clicked on it until it too has said Program Not Responding. Depending on the amount of resources being used (how many other programs you have open), it has usually come to life after waiting a minute or two. If you have a lot of other stuff running, close everything you don't need to run while you're working in PSP.
If you don't have 3GB of RAM installed, consider doing so.
I have had to reinstall PSP once as well. Nothing I did helped. Once I uninstalled it and reinstalled it, it worked again.
Sep 22, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
PSP X2 stopped launching
When it gets to the 2 second point just leave it at that and eventualy, Takes SEVERAL MINUTES, the finish screen appears. patience is rewarded,
Jul 06, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
Paint Shop Pro will not respond AT ALL!
not a hardware or major software prob, but see that if any other software have the same prob...?
you will have to scan your pc through a best virus cleaner or remover. then will have to install a fresh O.S, and then install Paint Shop Pro X2, it will run faster then before..
take care
shafky
Jun 20, 2009 | Corel Paint Shop Pro® X Full Version for...
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
Corel paint full uninstall
Try to reinstall the old version and then, uninstall it in order to proceed toa clean installation
Hope this helps
Oct 27, 2008 | Corel Paint Shop Pro Photo X2
Every time I run paint shop pro X2 it freezes right on start up. It freezes in the same spot every single time, which is when it says "loading Cache files" or something rather. I have no i dea...
Did you install the software update for the program. Also remove the software and delete the Paint Shop Pro folder off your HDD and download www.ccleaner.com and clean the registry with that software. Now reboot and re-install Paint Shop Pro.
Jul 23, 2008 | Microsoft Windows Vista Ultimate Edition
Corel Paint Shop Pro Photo X2 Full Version for PC (PSPPX2ENPC) Logo
42 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
