Question about Samsung DVD-VR357
Menu question im trying to copy my vhs tapes over to dvds but my main menu on has to options ... and no "copy" like the instruction manuel says. can you help?
    Problem Solver:
  • 5 Answers
Put a DVD in it's side, and a tape in it's side. At the top of the remote press "DVD". Press the "menu" button and you should get the selections you want. You can also load both sides as I said before, and using the 2 red buttons at the very bottom of the remote, press "To DVD" and it will start the copying the tape. You will be able to see it on your TV. When the tape is complete it will stop, or if you are only transferring a part of the tape, press "stop" when you want the copying to end.
Posted on Mar 05, 2009
    Sergeant:
    Champion:
  • 201 Answers
I use A tuner card in my computer to record and edit my vhs tapes this works best I use nero
Posted on Dec 07, 2008
    Genius:
  • 1,199 Answers
If the tapes are store bought movies (on vhs) you will need to buy a copy guard eliminater...you dvd recorder was made not to record copy protected materal
Why won't the Sony controls let me click onto finalize using a Sony TV w/recoder to transfer VHS to DVD?
Is the VHS tape you are trying to record a commercial VHS tape (movie)? If so, it may have copy protection on it. The recorder is probably programmed to prevent you from making and using DVDs of commercial copy-protected VHS tapes.
Nov 13, 2015 | Zenith XBR716
I have a grundig gr1000(b) vhs/DVD combo. Is it possible to record from video cassette onto DVD? It doesn't seem to be mentioned in the instruction manual. Thanks for your help.
Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
Nov 02, 2014 | Televison & Video
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Sep 26, 2011 | Televison & Video
I've had this unit ewr20v4 for about 5 years, never tried to copy from vhs to dvd until now. I get error message, unable to copy to this disk. called CS they offered an upgrade disc but will charge me...
You have a VHS that uses copy protection. Your unit is designed for copying self-authored DVDs, like you make from iMovie or another app, to VHS. It won't work with commercial VHS tapes with copy protection. The upgrade is probably a decoder circuit, and may be worth it if you plan to use your unit this way often.
Mar 21, 2011 | Emerson EWR20V4 DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
VHS cassettes stuck NOT in a VCR. I have a few old VHS cassettes that I want to copy to DVDs. The problem is that that the tape in these cassettes gets stuck. Not only in the VCR. When I use an external...
Yes,Loosen all the VHS cassette screws from the video cassette plastic cover.Take ur finger shaking and rewine wheel a few times with it with ur finger.The VHS tapes shoud work find now.
Dec 06, 2010 | Televison & Video
FINALIZING DVD+R DUBBED FROM VHS TAPES
The manual gives you incorrect info.
To FINALIZE disk:
1. Press [HOME] button;
2. select [SETUP].
3. Scroll down to DVD ICON and SELECT
4. Select [FINALIZE]
Perfect Answer provided by "petoNOVY" - THIS ANSWER ALSO APPLIES TO ZENITH XBR616 - I struggled for 2 years to find it!!! THANKS!!!
Dec 17, 2008 | Zenith XBR716
Copying VHS tapes to DVDs.
Which make and model number is the recorder?
Mar 18, 2008 | GoVideo VR5940 DVD Recorder/VCR
Samsung DVD-VR357 Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
