Question about Optimus H-4436 Electric Heater
Alarm light came on. no heat. still occilates
i cannot locate a manual or figure out problem.
  • 8 more comments
  • Anonymous Dec 08, 2008
    My Optimus is doing the same thing, it started yesterday. I have had it for about 2 years now (I purchased it at Sam's).
  • mawpeg Dec 13, 2008
    I have the same problem, only had mine for one year.
  • salemnagdy Dec 25, 2008
    I have the the same exact problem.
  • Anonymous Jan 27, 2009
    alarm light comes on and no heat is coming out
  • Anonymous Jan 28, 2009
    I have the same problem with the alarm light????????
  • Anonymous Feb 04, 2009
    Bill6082
  • Anonymous Feb 14, 2009
    alarm light on and no heat
  • pamkmitchell Mar 12, 2009
    Same problem here. Mine is not very old. How often does this happen? I'm thinking about returning mine to the store?
  • Anonymous Mar 14, 2009
    Alarm light comes on and heater will not work now. The heater is less than 6 months old.
  • Nananeu Apr 21, 2009
    Same problem-heater was a Christmas 2008 gift - used regularly - now oscillates but will not heat.
I have only had mine for 3 weeks when it did the same thing, I looked up and called Optimus Enterprizes @ 714 956-1300 they told me they warrenty it for 3 years. Send it back and they will repair or replace it. I am near them so I took it to their office @ 2201 E. Winston Rd. Anaheim, Calif. 92806. When I walked into the office the girl took my heater into the back and came out with a new one. No questions asked. I did not even have to show my Ebay paper work.
SO my solution is send it back.
Good luck
lasereleganc@earthlinknet
you may call me and I can look up in my manual
626 798 7077
Posted on Jan 15, 2009
  • sundiegocal Dec 30, 2010
    Thank you! I had two heaters with this same problem. I took them to the office like you said. The man there took the heaters back to see if he could do a quick repair, then decided it wouldn't be quick, so he gave me two new heaters, Didn't have to show paperwork. We'll see how long these last! Thanks again for the great advice.
  • 4 Answers
I read another article and tried the "smack it" method that worked for some others, but alas no dice, no such luck for me. Upon removing the back round cover I noticed a section of the wiring which is covered by an insulation sleeve & screwed to the back of the heater with a little metal clip had a red wire going in one end and a white wire coming out the other, so I suspected something like a fuse was being hidden inside. Bingo! Its part number is "SF119U-1", made by SEFUSE rated 15Amps/125degC. You can get 5 of them for $5 on eBay, or they probably have them or an equivalent at Radio Shack. The not-so-fun part is that it's soldered, so if you don't already have the stuff needed to solder, you're in for a bit more expense to make this repair. If you're handy, you can avoid any future problems by installing a circuit breaker, which will allow you to reset it instead of replacing it. RadioShack has a 15Amp breaker (pt# R59-15A) made by NTE for $5, also available on eBay. It has spade terminals, so you could actually make the repair without soldering, but I like to overkill and crimp them on, AND solder them.
Posted on Dec 11, 2012
  • Anonymous Oct 20, 2015
    How would you connect the breaker instead of replacing the fuse?
  • Anonymous Oct 27, 2015
    Thank You. It worked!
    Genius:
  • 1,199 Answers
Your heating elament is burnt out, wikk cost more to fix then replace!
Posted on Dec 07, 2008
OPTIMUS H-4438 ELECTRIC HEATER ALARM LIGHT UP NO HEAT STILL ROTATE
I took it apart found nothing. Put back together took the plastic screw driver with the unit on,gentlly tapped the plastic houding opposite of the heat senser at the top of dish and it works!
Nov 04, 2011 | Optimus H-4436 Electric Heater
Alarm light comes on as soon as I turn on heater, preventing heater from coming on.
You can replace this fuse with a circuit breaker from RadioShack (part # R59-15A), and then the next time it trips you can reset it, instead of having to replace the fuse, which requires soldering.
Jun 30, 2011 | Optimus H-4436 Electric Heater
Every time i turn on my heater, the alarm light goes off and the heater will not turn on.
I would buy another heater unless, that one is new and try to return it..
May 28, 2010 | Optimus H-4436 Electric Heater
Powers up but alarm lights up and no heat
I called customer support on this since everyone has the same problem. Behind the reflector is a cover that has 3 screws. Unscrew and you'll see two wires (a red & white). Inside the white sleeve is a fuse. Cut out the white sleeve and take the fuse out. Cut the fuse w/ the wires. Attach the white to the red w/ electrical tape. Make sure that wires are wrapped w/ the electrical tape. Support said that the fuse is not needed.
Dec 21, 2009 | Optimus H-4436 Electric Heater
Alarm button has appeared. We can't get heat from the coils
remove back (3 screws).. cut out white sleeve and remove fuse from beginning of wire to end on each end of fuse. Attach the red & white together and wrap w/ electrical tape. the fuse is not needed.
Dec 16, 2009 | Optimus H-4436 Electric Heater
Optimus H-4338 The warning light came on and now the heater will
there's no reset, but unscrew the 3 screws in the back. Cut out white sleeve that covers the red & white wires. Take the fuse out from beginning to end. Attach the white & red wires directly. The fuse is not needed. Wrap w/ electrical tape. You, me and everyone that has bought this heater had the same problem. I called customer support. This is what they told me.
Dec 09, 2009 | Optimus H-4436 Electric Heater
Optimus heater h-4438
Check on the heater coil using the multi-tester. Set it at Ohms 1 x 10 position.
1. Switch it off and disconnect it .
2. Disassemble the electric heater.
3. Put the multi-tester probe (red and black) at each
end of the heater coil.
4. If the reading is almost zero, then it is okey.
Otherwise, you have to replace it.
5. Then, reassemble the electric heater.
6. Plug it back to the electric outlet, and switch on.
Nov 03, 2009 | Optimus H-4436 Electric Heater
Optimus H-4438 Electric Heater
Optimus electric heater can be found on amazon, click here and take a look: Amazon com optimus electric heater. I hope this was helpful. Cheers
Jan 10, 2009 | Optimus H-4436 Electric Heater
Alarm light staying on.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Feb 22, 2008 | Heating & Cooling
Optimus H-4436 Electric Heater Logo
1,316 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
