Question about LG LRSC26910 Side by Side Refrigerator
The icemaker is not making ice, no water is getting through
We installed the icemaker on our bottom drawer LG refrigerator, and it does not make ice. We have checked the water line and the water is running through, but the icemaker does not seem to be getting any water.
  • Anonymous Dec 29, 2008
    My refrigerator suddenly stopped making ice. A while ago the dispenser stopped dispensing water. There is water in the hose getting to the fridge.
  • 4 Answers
Another user on this site is having a similar problem. What I suggested to that user is that they call the manufacturer before calling an appliance technician to see if there is a remedy for this problem in that it may be common with their product. Nothing beats saving money by making a free phone call. With that being said, I think the problem is in the solenoid of the ice makers. Water is getting to the solenoid but it is not turning on to allow flow beyond that point. It could be defective or it may be something as simple as trash or air in the line.
Posted on Mar 22, 2009
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
Tip
Water in the freezer compartment
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and embedding it in a block of ice, as well as puddling-up on the bottom of the freezer and eventually blocking the door from closing properly. Because the water seemed to be covering a wider area than you would expect from a blocked defroster drain I didn't believe that my problem was covered by the other FixYa recomendations -and it turned out I was right.
The problem turned out to be that the "funnel" that the water flows through to fill up the ice tray was blocked by a solid piece of ice. When the icemaker would call for more water it would flow down the clear tube (with the open slots on the top) hit the ice and spray/overflow in to the freezer compartment.
The solution was obviously to pop this ice out, but that did require me to remove the icemaker from the wall of the freezer compartment. To do this you
  • remove one screw from the bracket on the bottom of the icemaker
  • Slide the icemaker up and slip it off of the two screws with rubber grommets on them.
By the time I got to that stage I had already removed the basket from the main drawer and removed the pull out tray/basket from the drawer pulls (by simply lifting the plastic tab on the right side and lowering the plastic tab on teh left side). I am not sure if you can remove the icemaker without this step, but I believe so.
Also, if you want to entirely remove the icemaker from the freezer there is only one plug with wiring to undo. As I mentioned above, the water hose doesn't not connect to the icemaker, it ends above the "funnel" and the water drops in. So removal is much simpler than you might expect.
As for the cause of the ice block, I am not sure but I believe it was either because the ice maker made too much ise one time and some cubes could not pop out. When additional water entered the funnel it didn't flow in to the ice tray, backed up, and froze in the funnel. The other thought is that when the door was not closed properly while our grandparents were visiting, the ice melted and subsequently re-froze causing the problem.
on Dec 15, 2007 | LG LFD25860
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
I have icicles all over my freezer. They started on the door under the ice maker. It is making ice but it won't come out because it the turning thing can't turn because there is solid ice in the bottom of...
Your icemaker is surely at fault. Shut the water off at the valve, turn off the icemaker, and defrost again. Does it happen again? If not, check your icemaker assembly for leaks or replace the water inlet valve if necessary. Good luck.
Apr 24, 2011 | Refrigerators
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
The ice maker will not shut off on the LG refrigerator.
the internal switch that is supposed to shut the ice maker production off when the bucket is full has failed. Replace your ice maker
May 07, 2010 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
My freezer seems to be accumulating water under the drawer. it is coming from the back wall on the right, but there is no leak anywhere else. I do not have an automatic icemaker installed. What could be...
Plastic water bottles on upper shelves sometimes have small leaks. Remove all above water containers. Maybe you spill some water replacing ice trays? Identify the source of water..that will be the cause of problem.
Feb 16, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Icemaker makes too few cubes
Find the water source for the ice maker(most are under the kitchen sink and are tapped off of the cold water line to the faucets) You need to either shut off the tap by turning it clockwise until it is closed. Then you need to disconnect the vinyl tubing from the valve. get a bucket and place it where it will catch the water from the tap. Gradually open the tap by turning it counterclockwise until water starts to come out of the valve. If you have a large enough bucket open the valve all of the way. If the stream of water does not change then the valve is bad and needs replacing. If the stream is nice and strong then the valve is ok. Turn the valve clockwise to close it, reattach the vinyl tubing and open the vale all of the way. This should improve the quanity of ice cubes. If not then there is a cripmp in the vinyl line between the tap and the solinoid valve on the back of the refrigerator.
Jul 18, 2009 | LG LRSC26910 Side by Side Refrigerator
Ice maker not making cubes
You may have ice built up in icemaker where the water goes into it.  You will have to remove the icemaker and to get the ice cleared out.  Once that's done, you should be ok.
Jan 13, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer Not making ice
are u getting water to the icemaker? If Not check water valve for ice maker in back of refrig.
Sep 11, 2007 | Sub-Zero 650 / O Bottom Freezer...
LG LRSC26910 Side by Side Refrigerator Logo
154 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
