Question about Whirlpool GSC9455 Top Load Washer
Washer will not spin/drain properly.
I have a Whirlpool Gold Catalyst clothes washer. SM8280928
It goes thru the wash cycle but does not spin/drain properly.
I think it was overloaded and about 1/2 dozen socks were under the agitator. I removed them but it still does not operater properly.
Does the knob on top remove counter clock wise or clock wise?
What do you think I shoud do to solve the problem?
Thank you,
Ron Gross
  • 318 Answers
A large load will sometimes get out of the top of the tub and cause the lid switch mounts to break and then the unit wont spin or drain. just look under the top and if you see the lid switch just hanging or not in the right place then replace the lid switch.
Posted on Jan 07, 2009
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Will not spin clothes
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Whirlpool gold catalyst washer error code FF
FF on the catalyst models means the following. Let me know if you need more info or would like a link to where you can obtain a service manual for your washer.
If the transducer signals a high or a low water level for more than 16
seconds the washer will shut off and FF will flash.
• Press the RINSE OPTIONS button and select DRAIN/SPIN to drain
washer.
• Check the water level transducer hose and wire connections.
• Also check the pressure dome hose to be sure they are properly
connected.
• Check the water level transducer, see TEST #7.
Mar 04, 2008 | Washing Machines
Whirlpool GSC9455 Top Load Washer Logo
368 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
