Question about Sony KP-61S70 61" Rear Projection Television
No sound and dead screen
This Sony rear projection TV is about 6 years old; model kp-65s70. Smoke came out the vents when it quite-no sound and no picture. The red standby light flashes 4 times between pauses. What is my problem and is it worth fixing. Thanks!
  • 4402 Answers
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
  • 137 Answers
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Posted on Jan 04, 2008
sorry i couldnt have been more help. glad you figured it out.
Posted on Feb 27, 2008
  • 19396 Answers
SOURCE: Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Posted on Aug 30, 2008
  • 3 Answers
SOURCE: how do i fix my sony kp-46wt520 projection tv
Called sony and they said send it so we can help fix it.
Mine was a bad "g board"
Sent it to PA (penssylvania)
And they fixed it for & $88 you have to ship G-Board to them and they will return after they fix it if not repairable they will tell you.
(No charge until they fix it.. )
Mine works now and ready for superbowl....YEAH ! ! ! !
Posted on Jan 30, 2009
  • 10594 Answers
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Posted on Apr 15, 2009
0 characters
1 Points
My television is only 6 years old. Red lines have appeared in the form of a wave pattern on the screen. What does this mean?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have a colors shadows or 3D pictures look alike?Ur tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 27, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-65w5500 rear projection TV red tube needs replacement
there is a company called Video Display Which sells rebuilt tubes
Jan 19, 2009 | Sony KP-57WS500 57" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here:
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Sony KP-57WS500 rear projection red screen
sounds like the red crt is bad, you can get a replacement at the following link, if your not sure which one you need just leave them a email with your model number and what youre needing.
Sep 07, 2008 | Sony KP-53S65 53" Rear Projection...
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Aug 13, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony 52XBR Rear Projection
Sounds like some kinda convergence problem. Can you post an image please?
Jul 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61S70 61" Rear Projection Television Logo
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
