Question about Omron Automatic Blood Pressure Monitor w/ Cuff
Where can I get my Omron Digital BP Monitor calibrated?
It's about 5 years old and the diastolic reading is about 20 points off...I've been using it a lot more over the last 6 weeks and the numbers are not matching the Dr's readings.
Is there someplace I can take it in or send it in?
Thank you very much!
Can i calabrate my monitor ar do i have to send it somewhere to have it done
Posted on Aug 06, 2009
  • 74 Answers
Here is a link that give you repair information. I hope this helps.
http://www.omronhealthcare.com/product/warranty.asp
Posted on Dec 25, 2008
I installed new batteries to my Omron BP machine but I still have to use it with the AC cord...Where or how can I get it fixed?
Posted on Jan 04, 2015
My blood pressure seems to be going up and down ,,this morning it was 118/60..at the moment it is 139/60 I am an active 84 year old female
Those readings aren't bad, although the lower (diastolic) reading could be seen as a bit low according to published guidelines.
Blood pressure does vary through the day, and in your age group is more likely to possibly need management purely because the plumbing is not what it used to be when you were 18 !!
So to set your mind at rest, and to make sure there is nothing serious creeping up, get along to your doctor and ask about normal readings for you.
I see you possibly have your own BP meter, and that is a good idea, I have one also, an Omron (plug there). If so, take that too and ask the doc to calibrate it, that is, verify it is accurate.
Good luck
Dec 09, 2016 | Health & Beauty
Is a diastolic reading of 78 high or low?
Normal BP range is 120/80, although there are many factors to that must be considered. A diastolic of 78 would be within the normal range, Recommend consulting with your health care professional if you have concerns about your BP, and follow the treatment plan developed for you.
Oct 13, 2014 | Omron Health & Beauty
WHERE TO FIND TECHNICAN FOR MONITOR CHECK?
I would simply have it done manually at your doctor's office, and then immediately or simutaneously take it (on the other arm) and compare. I've not heard of BP monitors needing any regular recalibration, so I'm not sure I'd worry too much.
Jun 07, 2012 | Life Fitness Ultra Blood Pressure Monitor...
My Omron blood pressure monitor does not give me a correct reading. It is about 20 point higher than is should be when compared with a professional monitor. Can my monitor be re-calibrated to read the...
BEFORE TAKING THE READING DONT USE IT BEFORE COMING UP FROM STEPS OR SUDDENLY WALKING AND TAKING READING
IF YOU TAKE READING IT WILL COME HAZARDIOUS
SIMPLY RELAX FOR 10 MINUTES AND STAY CALM WITHOUT TALKING
AND FOLLOW AS PER MANUALS TO TAKE READING
Sep 10, 2011 | Omron Automatic Blood Pressure Monitor w/...
My Omron HEM-712C digital blood pressure monitor is pretty consistently showing my pressure at 140-155 /80-95, but when my blood pressure was taken at a medical appointment yesterday, it was 92/63 -- a...
First, I do not believe there is any accurate way to measure blood pressure without having a valve installed; not a practical alternative.
The standard method using an arm-cuff and stethoscope is highly dependent on the person doing the measurement. Once my hearing started to fail, I had to go to a digital meter and found after three of these which failed and comparing my current Samsung to three different methods; manual, an elaborate 'calibrated' digital on a stand and another 'calibrated' cuff-type during an examination by a professional, none of these agreed better than 10-15 mm and the worst was 25-30 mm apart.
Using the average of those 'profis,' my current wrist-type digital measures about 10 points low on both systolic and diastolic so I just ignore the absolute numbers and use it only to determine relative deviations. For that, mine is repeatable enough.
Sep 16, 2010 | Omron Automatic Blood Pressure Monitor...
Where do I get my omron bp monitor calibrated
I assume you mean checked for accuracy - something that you should do every two years. I assume you live in Canada or the US, if so please contact OMRON at the number below. They will be able to direct you to a service centre near you.
CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available
Monday through Friday - 8:30am to 4:30pm CT
Apr 27, 2010 | Omron Automatic Blood Pressure Monitor w/...
Where is omron bp monitor service center in india my bp monitor doesnot get enough preesure and shows no 50 on the screen.
call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
Jan 19, 2010 | Omron Automatic Blood Pressure Monitor...
Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Mar 23, 2009 | Health & Beauty
Omron Automatic Blood Pressure Monitor w/ Cuff Logo
4,992 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
