Question about Jenn-Air JJW8230D Electric Double Oven
F2 code on Jenn air double oven
I have a jenn air double oven. I cleaned the top oven and after it was done I get a F2 code that will not go away, even with turning off the power. Any thoughts??
  • nevada101 Dec 28, 2008
    I have the same problem as well. Did you ever find out what the cause was? If so could you fix it yourself or did you need to have a serviceman fix it?
One website said its a relay board problem. Years ago I replaced the entire electronic board and did it myself and I am not overly good at such stuff, so it can be done if you find the correct part. I am having that problem and am searching for a relay board or whatever it is.
Posted on Feb 06, 2009
My Jenn Air double oven giving error message saying low fan speed and will not work! Any suggestions?
It may be possible that the fan blades have built up grease and dust causing a drag on the blade. Clean the fan blade and see if it goes away.
Oct 02, 2014 | Jenn-Air Ovens
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
Why does it keep turning off?
EE-217 M-217 no control panel function - Fixya
www.fixya.com > ... > Jenn-Air > JJW8230D Electric Double Oven
Apr 10, 2014 - EE-217 M-217 no control panel function - Jenn-Air JJW8230D Electric Double Oven question. ... F7 fault code on the Jenn-air W30400W.
Jenn Air Dual Fuel Downdraft Range Error Code EE-214 M-214 ...
forum.appliancepartspros.com/...repair.../506426-jenn-air-dual-fuel-dow...
Nov 12, 2012 - 2 posts - ‎1 author
After a power surge a few weeks ago (apparently caused by a log truck taking out the power lines), my range gave a weird error code: EE-214 ...
I get error codes m-214 and ee-214 on power up on a Jenn Air
www.justanswer.com > Appliance
Oct 11, 2009 - I get error codes m-214 and ee-214 on power up on a Jenn Airjes9800bas range. I replaced the clock computer board, it still has the same ...
JENN AIR Error Codes, Fault Codes - Appliance Parts Online
Nov 02, 2010 | Jenn-Air JJW8230D Electric Double Oven
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Top oven has an error code (f2) It happen after a cleaning
F2 - Oven Temperature Too Hot - Depending upon model, replace relay (if present) or oven temperature sensor. Make sure to check sensor harness.
Dec 09, 2008 | Jenn-Air JJW8630C Expressions Collection...
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Aire double wall oven
Get a long thin flat blade screwdriver. Gently pull the probe with one hand and press on the back side of the probe connector with the screwdriver until you feel no slack in the wires. Don't pull too hard! Rotate the blade of the screwdriver until the connector lines up with the opening and puill it through. Works for installing the new one too.
Jan 08, 2008 | Jenn-Air JJW8530C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
562 people viewed this question
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
