Question about Epson Stylus CX4600 All-In-One InkJet Printer
Epson Stylus CX4600 all in one printer, scanner
I have changed one of the colors which was indicated "out". Now the printing is very faint and can't be read easily. Indicated cleaning the ink heads. How do I do that?
Does not work, try calling epson for a replacement
Posted on May 31, 2007
    Problem Solver:
  • 15 Answers
Under Maintainance in the properties of the printer it gives you the option to clean the print heads. Should work
Posted on Feb 27, 2007
Epson Stylus CX4600
Did the message go away?Do you understand what the message is implying might happen if the pads are not changed?
these people sell a reset solution:http://www.2manuals.com/index.php?cPath=2_39
Aug 31, 2012 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus cx4600, not working
the printer wont work it will copy but not print anything off computer
Feb 01, 2010 | Epson Stylus CX4600 All-In-One InkJet...
Epson CX4600 printer - will not print color at all
no it should work at it is. if you installed the plug and play printer driver. have you removed the protection tape from the inc tubes?
Oct 12, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson cx4600 tubes are clogged
hi there
first you can try cleaning the heads of the cartridge with the software which has come along with epson this will solve your problem if dont then please change the cartridges or call epson service center they provide u onsite warranty
Nov 08, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus cx4600 all in one
remove the printer inks & use soft issue paper to clean the printing head. how long have u be using this ink on the printer?. check for the ink level if its too low, the output will be very faint.
thanks. let us know if we should add more tips.
Oct 05, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Sep 07, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus cx4800
first try a stand alone copy, put something on the scanner bed and try to copy it... it this is blank then do some head cleaning and verify if it can now print by doing a nozzle check pattern
Sep 05, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600
If all of the lights on the control panel are flashing and you see the letter E in the Copy window, the print head may not be able to move back and forth freely. Follow these steps:
  1. Turn off the Stylus CX.
  2. Open the scanner.
  3. Remove any jammed paper or other obstructions from the paper path.
  4. Carefully lower the scanner.
  5. Turn the Stylus CX back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Stylus CX.
And the last thing you could do, is to check if the rod where your carriage slide is dry...if so put a little bit of oil on it
Apr 03, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
May 05, 2006 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
