What should I do? I don"t want to use something to push the little mini CD farther in and I'm afraid if I push it in I won"t be able to get it out without damaging the computer or sticking something in to pull the CD out. I could damage the CD/Laptop or both?
Call the phone # on the brochure or your service plan and they will send a full size disk for free.
I have a XPS 1530 and I had no problem with the CD. I put it into the slot, it sucked it in. Downloaded the program, and when I pressed eject, it ejected the cd. I it has a sensor in the dvd/cd drive. It will not eat it.
Exactly, It's states in the user manual This system supports only 12cm discs. You need to have a copy made of the disc on a standard size CD. I would take the disc to Walmart along with the documentation showing why it will not work. Inform them this is true with all slot-load drives. Have them accept responsibility for copying the disc.
http://www.fixya.com/support/r5393255-windows_password_recovery
If you have lost
windows password, the best thing for you is creating a password
reset disk.Actually,when you add a password to your pc,the
first thing you should do is creating a disk in case you lost the
password.But how to make a password reset disk after you have lost
the password ? Follow these
You need to prepare:
1:A blank
CD/DVD or USB flash drive
2.A computer which can link to
internet
3.A program called Windows
Password Key
Then let's begin
Step 1.Login to a PC which
can link to internet,Download and install the program from in that
PC
Step 2.Run the program and burn to CD/DVD OR USB flash
drive
Step 3.Turn to your locked PC,insert the newly create CD or
USB to your drive.Reboot the Computer
and then follow the instructions,it is very easy to use.
Lost user password in XP with
networking set-up on HP
The best way to do this is using the Offline NT Password &
Registry editor.
You can download it at the following link:
http://pogostick.net/~pnh/ntpasswd/
This
utility will enable you to reset the password of any user that has a
valid (local) account on your Windows NT/2k/XP/Vista etc. system.
The
link above includes some directions on how to use this utility.
