Question about Dell Dimension 2400 PC Desktop
Contrast 100 window keeps appearing on screen
Keep getting red Contrast 100 window on screen
  • 4 more comments
  • pravinrajiah Dec 21, 2008
    Screen dimensions also change automatically
  • djboydo Mar 30, 2009
    window showing contrast on screen with 2 x %signs . screen getting bright then dark
  • Anonymous Apr 21, 2009
    "contrast 100 window keeps appearing on screen and I am using a dell e310 desktop
  • zeekfeer May 23, 2009
    just started popping out since yesterday...
  • xpok7 May 11, 2010
    What operating system and monitor are you using?
  •  D.RaghavendraRao
    D.RaghavendraRao Apr 22, 2013
    how to remove luminance contrast figure on my desktop.
  • 28 Answers
Try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Posted on Jun 10, 2009
2 Suggested Answers
  • 5 Answers
SOURCE: contrast 10My problem is that the contrast is appearing in the screen of my flat screen and automatic decrees the contrast and it?s blocking the center part of the screen window keeps appearing on scr
There is no feasible way to fix this. The problem is a short in the circuitry of your flat screen. If the monitor is off warranty, it's cheaper to replace the monitor than to have it repaired.
Posted on Jun 03, 2009
I Can not see the screen on my pitney bowes dm100i?
Screen contrast probably needs to be reset which can be done by:
1. Unplug the power cord
2. Press the #4 AND KEEP HOLDING IT DOWN UNTIL METER IS FULLY started aafternext step.
3. Keep the 4 button pressed & plug the power cord in, while keeping the 4 button held down.
After meter fully boots the screen will be restored to normal if contrast settings were the problem.
If this doesn't resolve the problem, the screen or control panel is bad & should be replaced. This should be covered under yourpPitney Bowes warranty while meter is onlease.
Apr 29, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Contrast 100 keeps appearing on my screen. How do I get rid of it
reset your monitor settings to deafault and disconnect it from your videocardand connect it again
May 15, 2011 | Acer Power FV PC Desktop
Why would I keep getting a red rectangle box in the middle of my monitor screen that says " CONTRAST 100
It's there to notify you that a setting on the monitor is not wisely selected - lower the contrast to less than 80. Ideally you should reset the monitor to default values - use this option from the menu.
Sep 19, 2010 | Dell Computers & Internet
Contrast menu keeps popping up in my moniter,it is a hcl moniter,the menu is not the normal adjustment menu that appears in the moniter which has all options like colour,brighteness etc.its just like a...
mmm look you have a setting problem reset the screen to it's defulat if it didn't solve the problem you will have to change the press bottoms and you will need some who know electronics to help you with the board but first try to rest it to the defulat settings
Nov 15, 2009 | ViewSonic VA721 17" LCD Monitor
Contrast 100 box
That would be the monitor and not the PC. try going to menu on the monitor and doing a factory reset.....if that doesn't work unplug for 3mins and try agin....if neither work then your monitor is faulty. Hope this works out for ya
Nov 02, 2009 | Dell Dimension 2400 PC Desktop
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Contrast 10My problem is that the contrast is appearing in the screen of my flat screen and automatic decrees the contrast and it?s blocking the center part of the screen window keeps appearing on scr
Jun 02, 2009 | Dell Dimension 2400 PC Desktop
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
AOC 15" CRT
just change the botton switch.... with a new one...
Oct 31, 2008 | AOC 5 En 15" CRT Monitor
Contrast Menu appears after switch On
Contrast Menu appears after switch...
Jan 02, 2008 | Philips Standard 105S Monitor
Dell Dimension 2400 PC Desktop Logo
2,084 people viewed this question
Alun Cox
