Question about Freud FT2000E 3 Router
Replacemaent screws that hold phonelic plate to base
What I am actually looking for is the size of the thread and size of the screw so I can purchase the same screw but only longer for another application.
Mike C
    Sergeant:
  • 359 Answers
Take old screw to hardware store find a nut that fits then calculate the length of screw need in the same thread and size (safest way because even the same mfg will vary on bed screws and this is fool proof
Posted on Dec 11, 2008
Want to install on wood beam, what size drill bit needed for included wood screws
Look at the wood screw threads and hold a drill bit against it. Choose a drill bit that is smaller in diameter than the threads on the screw. Works for any size wood screw.
Mar 11, 2016 | Drills
Can I unscrew the base plate and fit another Velcro round pad
the velcro adapter pad unscrews from the spindle
just need a very thin spanner to hold the shaft while you unscrew the pad--normally only hand tight
most shafts are common size so any pad from another machine will most likely screw on
there may be even universal pads on e-bay if you can identify the thread size
Feb 16, 2016 | Tools & Hardware - Others
The 5 cap screws that hold the bezel ring over the throttle slide: do they actually thread into something?
These cap screws thread into the basket inside the hull of the WingMan. This basket holds the mechanical parts and the potentiometers. If you wish to take a look on the interior of the hull (or case), it's better to open below; the bottom plate is secured by 5 Phillips screws located in the middle of the cushioning rings - except one of them, located nearby. Be careful.
May 03, 2014 | Logitech WingMan Extreme Digital 3D...
What size screws do I need to attach a front license plate to a 1995 Cadillac Sedan DeVille ?
usually id say just look around in the junk drawer for some fine thread like that hold knobs on the cabinet they about the right size
Aug 23, 2012 | Vehicle Parts & Accessories
Centrex top loader washing machine Model # CTW60519 6kg Auto Washer. When washing the center screw holding the base plate unscrews. The base plate lifts and the clothes are not washing clean. We have...
The part that the screw holds is turning independently of the screw. Remove it and inspect for torn splines or other motion locking device. Repair or replace the part using Loctite on the screw threads.
Sep 14, 2009 | Washing Machines
I have a 37 inch olevia hd tv..It was mounted on the wall but now we want to put it back on the base and cannot find the screws to reattach the base to the tv. Can you tell me the size of the screws?
This is a difficult one as you have about 50sizes possible for this one. Try calling olevia and giving them the model # they might have that info but its pretty technical and more then likely you'll need to go to a Home depot and just pick up several fine threaded screws (about $.05-$.10each) and try em all to see which one fits. Its a pain but may be the only way. Make sure you don't get them too long as this will damage the threads or not tighten the mount. Try about 1" to 1-1/2" screws. depending on how thick the base plate is. you want about 3/4" of the screw inside the tv depending on how deep the threads (can stick a toothpick inside it to gauge how deep) so ad 3/4" to the thickness of the base plate.
Sep 12, 2009 | Televison & Video
Need to replace the power cord
This is actually one of the easiest repairs to make on most dryers.
Unplug the dryer from the wall of course.
At the point where the dryer cord enters the dryer itself there is usually a plate. One screw should hold this plate in place. Remove the screw and pull the plate out (it should only be held in by a couple of tabs). The cord is attached to the power supply with three (or four) terminals. Back the screws out and slide the cord out. Make careful note as to which color goes to which terminal. Usually the black (or red) color goes to the gold screw and the white goes to the silver screw. The green screw holds the ground wire in place which is also usually a green cord.
Once you have done this step then loosen the screws that hold the cord in place on the plate. This fitting should open as you loosen the screws and the cord should pull out easily. Then thread the new cord through the fitting and reverse the process. Just remember to thread the cord through BEFORE you connect the wires so that you don't have to undo your work!
Hope this helps!
May 25, 2009 | Whirlpool Dryers
Screws do not hold hood to base
Get a tube of five minute epoxy at your local hardware store. Fill each screw hole with epoxy and then insert the screws. Let it sit for a bit and you will be back in business.
May 20, 2009 | Black & Decker String Trimmer Cordless 12"...
Freud FT2000E 3 Router Logo
96 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
