Question about Kenmore 43142 Front Load Washer
No wash cycle activation
Water fills and when time to activate wash cycle smell hot electrical smell and no agitation, all others work, spin rinse etc.
This was mistakenly entered as a frontloader. Should have been a top loader. Sorry
Posted on Dec 08, 2008
Speed queen washing machine fills water but does not agitate but all other cycles spin and rinse working perfect. i took out the belt and started the cycle and the motor was moving fine.
the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
Nov 10, 2015 | Speed Queen AWS44NW Top Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Whirlpool washing machine won't rinse nor spin. I changed the lid switch but still won't work
The spin function is normally controlled by water level control switch not allowing operation until all water is pumped out,rinse should activate water valve to add clean water,if machine fills ok initially the problem seems to be in the controller not activating certain parts of the normal cycle.
Apr 30, 2011 | Washing Machines
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
