Question about HP iPAQ RX3715 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
Hi I am unsuccessfully trying to connect my ipaq to the internet using a wireless router, but to be honest I don't really know what I am doing. I have cable broadband & have fitted a wireless cable/dsl broadband router with access points. The router appears to be working ok & I can access the the setup page OK. My Ipaq is showing a unnamed wi-fi connection available but I cannot connect to it. I have tried various settings to no avail & ultimately get the message: 'Cannot log on to the wireless network. This network requires a personal certificate to positively identify you' Any help would be gratefully received. Thanks Jon
  • Anonymous Jan 26, 2009
    hi, i have the same problem and your steps does not solve this issue..pls help
    Novelist:
    Scholar:
  • 111 Answers
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Posted on Mar 06, 2007
SOURCE:
I cant get wireless on my handheld hp ipaq 2200
change the security settings if any in the wireless router.... use 64bitWEP password for the router and if it is a BELKIN wireless router then WiFi protected setup should be disabled in the roter....
contact router's technical support to do settings in it....
Apr 28, 2010 | HP Computers & Internet
IPAQ RX3715 can't log on to home network
Try upgrading the firmware on the router and then connect the IPAQ and computer to the wireless network
Jun 11, 2009 | NetGear RangeMax Dual-Band Wireless-N...
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
Hi, my hp ipaq hw6950 won't connect to my wireless router. It endlessly says connecting... connecting... connecting... Thanks
try resetting the router and try connecting check whts the wireless standards in the router and the ipaq and config according to that for instance if ur router can support b then try entering the setting manually it will work try entering the correct wireless key
Nov 01, 2008 | Computers & Internet
Hp ipaq 4240
Turn your Linksys router off and back on again, then try connecting on your iPaq again. If that fails, do a soft reset on your iPaq and try again. If that fails, do a hard reset. Also, do you have any wireless security set up for the router?
Sep 07, 2007 | Computers & Internet
Wireless connections
Is your router setup for security? For example on your laptop, did you have to enter a SSID & WEP key in order to get connected to your wifi router. Also, see if your router is setup for MAC filtering, may be possible that its blocking your handheld device from connecting. If thats the case, then you would have to do the same steps on your handheld device has you would on a laptop.
Sep 03, 2007 | Computers & Internet
IPAQ Rx 3715 Internet settings~ conectivity problem
I have a few thoughts.
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
http://www.freewareppc.com/communication/hitchhiker.shtml
Hope it goes well! I'll try again if this does not work!
Aug 29, 2007 | HP iPAQ RX3715 Pocket PC
Can not figure out how to access the internet with ipaq.
Hi, If you haven't yet solved your problem, use an active sync connection throught bluetooth for example. Once the active sync is connected to the device, you can browse the internet using your PDA. For more information please post back.
Dec 24, 2006 | HP iPAQ RX3715 Pocket PC
Internet explorer browser
It's not the iPaq that has the problem. Some sites are just not PDA compatible. I'm sure the new windows mobile 2005 has better web compatibility but I don't know for sure. You can download a shockwave/flash player for windows mobile but I have not seen a java download yet.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
1,267 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
