Question about Durabrand HT-3915 System
Wires hooked up wrong on back of subwoofer - Durabrand HT-3915 System
  • 75 Answers
Connect the wires to the corresponding jack for example if one end of the wire is connected to the right speaker same as connect the other end to the same jack in amplifier or player...like wise connect other wires...
Posted on Dec 08, 2008
My KLH powered sub maks e a humming sound when i plug it in but it only hums when the speaker is hooked up i tried others but did the same eventually speaker started smoking would wrong fuse do that
Wrap a wire around the outside Metal of your rca jack in back of your radio and ground the other end of that wire to the back of your radio and the noise goes away
May 09, 2015 | KLH Audio Players & Recorders
Ok so i have a kenwood set up , 2 12 inch subs and amp, all the fuses are fine the connections inside the box to the subs are fine , the head unit is all hooked up and fine there is no cuts in any of my...
It does sound like a problem either with the amp itself or the wiring. Since the wiring is the easiest thing to check and cheapest to fix start here.
1.Make SURE the ground wire is secured to the frame of the vehicle.
2.Make sure the remote wire is hooked up properly.
3.Check the component/rca cables
4. Check the settings on the amp itself
Post back and let me know if you find anything wrong with one of those troubleshooting ideas.
-Daniel
Aug 09, 2011 | Car Audio & Video
I have 2 12 inch kickers cvr and i have the rockfordfosgate g15002 hooked up and briged and it keeps cutting off
This is usually due to wiring the subwoofers to the wrong Ohm load. Normally those amps are rated at a 4 Ohm load. It sounds to me like they are wired down to a 2 Ohm load and bridged. It's a protection situation for the amp. If you have a multimeter, disconnect the woofers from the amp. Next, hook the meter up to the subwoofers where the wire or wires are coming out of the box. If you can give more information on the woofers, I can give you a better idea on what the numbers that you should see. It depends on if they are dual 2 or 4 Ohm woofers.
Apr 23, 2011 | Rockford Fosgate Car Audio & Video
Connected home cinema today and cant get sound when watching the tv
no sound out of tv?
sometimes that happens and you need to wire sound back to your tv from your amp. usually normal audio cables work.
or if you have no sound on your stereo from the tv.
you must have cables hooked up wrong or your amp is on the wrong selector eg. tuner,tape,dvd,cd. etc
Feb 21, 2010 | Panasonic Audio Players & Recorders
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
Subwoofer Optimus
I added the subwoofer wires to the right and left front speakers.
Apr 01, 2008 | Onkyo TX-SR601 Receiver
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Durabrand HT-3915 System Logo
234 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
