Question about Whirlpool Duet GHW9150P Front Load Washer
My WP duet washer wont restart after adding a garmet!
I pressed the start button, then remembered that i had another peice of clothing to add and i pressed the pause button (not 30 sec into the washing period: and now it wont start back up!!!!!!!
    Problem Solver:
  • 14 Answers
Have you tried unplugging the washing machine then start over,this may clear it out and in able you to start fresh.
Posted on Dec 09, 2008
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
The water level is too low in my LG waveforce top load washer. How do I add more water?
press the pause ,,,,at ur left hand situated the water level botton,,,,,press to incress ,,the is a level indicator,,when reach to ur maximum choice then press the pause start botton again
Jan 16, 2015 | LG Washing Machines
My washer machines door is locked wont open. And won't wash the clothes in them
  • Unplug your Maytag washing machine for 30 seconds.
  • Plug your washing machine back in, and after 30 seconds, push the "Pause/Cancel/Stop" button two times. Choose a wash cycle.
  • Press the "Start" button until the wash cycle begins to ensure that the washing machine is functioning properly
  • Nov 09, 2012 | Washing Machines
    I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
    My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
    Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
    Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
    Step 1: put the plug back in and turn the power back on.
    Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
    Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
    Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
    Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
    Hopefully the cycle will run without a problem.
    Mar 26, 2011 | Electrolux Washing Machines
    Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
    Buttons:
    Pre-Wash = K1
    Delay = K2
    Temp = K3
    Spin Speed = K4
    Add Garment = K5
    Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
    2. Press K1 or K2, it will change from t01 to t12.
    3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
    b. t02:Show fault code test
    Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
    Jan 16, 2011 | Washing Machines
    Whirlpool washer duet is flashing after adding garmet. Will not return to washing
    April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
    MODELS: See additional page for Kenmore model numbers
    COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
    CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
    PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
    MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
    Clothes are getting torn in the washer. How do
    check the fins in the washer,and run your hand in the washer make sure there is nothing caught in the basket
    Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    216 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
