Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
S video question
I have an HP Pavilion dv2000 laptop. Can you tell me how to get the S video cable to work? When I hook it up to our TV it can not pick up the signal. Im not sure what we need to do. One suggestions was to press the fn and f together to switch monitors, but that does not work either. Any suggestions?
  • stony210 Dec 07, 2008
    Thanks for the suggtion, but it did not work, and I using Vista. Do you think it has something to do with the 7 prong jack? I was reading some troubleshooting online and read somwhere that the problem was due to not have a 4 prong. How about VGA. What do you think about trying that cord?
    Sergeant:
    Novelist:
  • 192 Answers
This can be done a couple of ways. I hope I am right in assuming that you are using Vista. If not, let me know. Not all F keys have the same functions on different laptops, so am not sure if you're pressing the right one. The one you should be looking for will have 2 square boxes (1 white, the other filled in, seperated by a vertical straight line).
If that is the one you've already tried, then I would assume the laptop hasn't been set up for external display. Connect the cable to the external display, click on the Start Menu, then All Programs. Open the Accessories folder, then click on Windows Mobility Center. Click on connect display.
If you have an NVidia board/chipset, you can right-click anywhere on your desktop and choose the TV Setup Wizard or Multiple Display Wizard. Once either of these are done, you should be able to switch between the two displays.
Posted on Dec 07, 2008
  • Timothy Farley Dec 07, 2008
    If your tv has a VGA port on the back, then yes, it'll work. It just turns your tv into a monitor. That's how I connect mine. You might not even have to set up multiple displays, I didn't. The only thing to remember is to set your laptop resolution to a resolution that your tv supports.
    i.e. my laptop is normally set to 1440 x 900, but my tv doesn't support anything higher than **** x 768. So before I connect my tv via VGA, I change my laptop resolution to 1330 x 768.
    1024 x 768 is the most commonly used resolution, so set that one first and work your way up from there.
2 Suggested Answers
  • 489 Answers
SOURCE: S video question
pushing FN is not able for TV. it for VGA out.
TV must be AV mode. you need to S video cable plug in the both side correctly. and then you will have a view. if you dont maybe your S video out is not working.
Posted on May 31, 2009
I HAVE A HP DV2000 LAPTOP WITH VIDEO ISSUES , I REPLACED THE MOTHERBOARD BUT STILL NO PICTURE ALL LIGHTS ARE ON AND THE FAN IS WORKING BUT NO VIDEO..
Hook a spare monitor to the video output, usually on the back. If you get a picture it means the inverter board is bad, or the backlight behind the LCD display, check to make sure the round video cable is plugged into the motherboard. But, if the symptom is the same for both screens, the problem is the Video Graphics Card normally built into the motherboard. If the connector to the LCD is damaged that would explain the issue of no video.
Mar 13, 2012 | HP Pavilion dv2000 Series Laptop Full...
Hp pavilion dv2000 sound driver
you can download the driver from this site
http://go4download.com/hp-pavilion-dv5-driver
Jan 09, 2011 | Computers & Internet
Hi my laptop is HP Pavilion dv2000 And light on
You have Video Failure... As A Result Of A Faulty Nvidia Graphics Chip..
Look to See If Your Make/Model Is On HP's Extended Service Warranty, To Replace Your Motherboard At No Cost...
Dec 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Sound problem in hp pavilion dv2000 with window xp
well u need to tell me which series of pavilion dv2000 Note it's located on the label as in this example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Jun 06, 2009 | HP Pavilion dv2000t Notebook
S video question
May 31, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Jan 16, 2009 | HP Pavilion dv6000z Notebook
My monitor is not working hp pavilion dv2000
hook a vga monitor to the external port on the lappy use function keys to see if it is putting out a video signal if not mobo / video card may be bad if it is cable / lcd maybe bad or could be a virus
Oct 24, 2008 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
1,206 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
