Question about Texas Instruments TI-86 Calculator
Graph not working
I was checking out the zoom and after that the graph stop working.
It says Err: window range.
how do i fix it
  • Texas Instru... Master
  • 7,993 Answers
The window ranges you chose may be wrong. Use ZoomStd ( Zooom standard) or use values that satisfy inequalities Xmin less than Xmax and Ymin less than Ymax. make sure the ranges Xmin, Xmax and Ymin, Ymax cover the area of the graph you are interested in.
Hope it helps.
Posted on Sep 23, 2009
Window range error
What type of plot? Try turning off the stat plot features.
Dec 03, 2013 | Texas Instruments TI-82 Calculator
My TI-53 calculator will not graph all it says is ERR: window range
I do not know of any TI calculator with Model number 53, but I will try to give a general answer. If you get a window range error that means that the Window limits are not set correctly. For example, the lower limit in X, Xmin must be algebraically smaller that the upper limit, Xmax. The default for the TI graphing calculators are Xmin=-10, and Xmax=10. Similarly the Ymin must be smaller than Ymax. The default limits for the y-variable are Ymin=-10, and Ymax=10. If your calculator has a Zoom function ( if it is a graphing calculator, it must have it) then Press Zoom key and select Zoom Standard or ZoomStd.
Jul 16, 2011 | Texas Instruments TI-89 Calculator
For my ti-84 I try to graph & it says ERR:window range...but when i try to fix the range it won't allow it...is there a good widow range to have for all graphing purposes?
There is no one good window range for all graphs, since graphs can have different areas of interest.
Press the ZOOM key, then select ZStandard. This will restore the window settings to the default range, which will at least allow the graph to be displayed. You can then change the window range and/or zoom as desired.
If this doesn't do it, please reply to this post, giving the function(s) you're trying to graph and your current window settings.
Feb 15, 2011 | Texas Instruments TI-84 Plus Calculator
When graphing, after a formula is entered and the graph button is pushed, all I get is "ERR: WINDOW RANGE" What needs to be done? cewatts@live.com
Start by pressing ZOOM (the center function key on the very top row of the keyboard, just below the display) and select 6:ZStandard. This will set the window range to the standard default. After that, you can either zoom in on an area of interest or press WINDOW (just to the left of the ZOOM key) and enter in the window range.
Jan 13, 2011 | Texas Instruments TI-84 Plus Silver...
I have the TI-84 Plus calculator and when i try to graph anything, it says ERR: WINDOW RANGE. What do i do?
Press WINDOW (the second key on the row of function keys at the top of the keyboard) and check your settings. Alternatively, if you're plotting a function press ZOOM 6 to set the standard window range and if you're plotting data press ZOOM 9 to set the range to go with the data.
Oct 19, 2010 | Texas Instruments TI-84 Plus Calculator
My calculator doesn't graph anything just says err:window range and 1:quit and the graph is weard!!help meeee please !!!!!
Try using the standard Zoom.
If you are drawing Y=f(X) functions, press [ZOOM][6:ZStandard]. The window dimensions will be [-10, 10] for X and the same for Y.
If you are drawing polar graphs, in addition to the X,Y windows dimensions, you have Theta min =0 and Theta max =2*Pi =(6.28)
Feb 08, 2010 | Texas Instruments TI-84 Plus Silver...
ERR: Window Range
Press ZOOM and select Zoom standard (ZoomStd).
Alternatively, press the WINDOW key to access the window range setup
Set Xmin=-10
Xmax=10
Ymin=-10
Ymax=10
These are the standard dimensions of the window.
You can change the dimensions as long as Xmin is less then Xmax, and Ymin is less than Ymax. Do not make Xres close to Xmax-Xmin.
Jan 10, 2010 | Texas Instruments TI-83 Plus Calculator
Graph feature not working on my TI-83 Plus
Simple:
Hit this sequence:
"ZOOM" "0"
That is for the "Zoom Fit" option. The calculator does not like the window you have for the equation you've given it. With this option, it will automatically give you the best fit in the window for the equation!
Nov 14, 2008 | Texas Instruments TI-83 Plus Calculator
TI 83 Plus
Try hitting "ZOOM" then "0". This is for the "Zoom Fit" option. It will automatically adjust your window range to best fit your equation!
Sep 27, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-86 Calculator Logo
89 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
