Question about Brother CS6000i Computerized Sewing Machine
Display shows E1
My first CS6000i stopped working and dispaly E1 Bought another one and after abour 12 hours use it alsoquit working and displayed E1. Really frustrated that they don't last very long. What can I do?My bobbin will wind but, then when I go to sew it shows that "E1" error and will not even sew the fabric. Lisa
    Genius:
  • 1,239 Answers
HI
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!)
There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!)
It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some
Pictures of the wiring so it will be much easier to put it back together.
THANK YOU
Posted on Dec 07, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    someone finally gave the manufacturer's phone number (1-877-739-4648)!
  • 88 Answers
You should go to their website under customer service and see if they know what causes that e1 message ,it seems to be an odd coincidence that this has happened to you twice.try that and let me know what happens.
    Sergeant:
    Champion:
  • 201 Answers
Are you sewing tough materials? Can be on the bottom if you sew the gears go out of timming. But usualy when sewing tough materials
E 1 error message
Make sure you lower the presser foot before continuing the operation.
The foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
and the reverse/reinforcement stitch button
was pressed while the presser foot was raised.
Mar 01, 2014 | Brother CS6000i Computerized Sewing...
Brothercs6000i E5 E6 wont sew
could have a problem with the computer part of the machine, it would be a good idea to have it checked.
Nov 24, 2013 | Brother CS6000i Computerized Sewing...
How do I fix the E1 error code?
Abnormal rotation in main motor Motor runs at more than maximum speed
Look HERE for Service Manual
May 22, 2012 | Brother CS6000i Computerized Sewing...
What does error E1 mean on a brother CS6000i
hello,the E1 code simply means the machine is working so hard,you can follow the information below to help you fix the problem,
The instructions for bobbin winding tell you to click the start button for the bobbin to wind. When you do that you get that E1 with a beeping. What they don't explain is that in order to press that "UP" arrow button to get the bobbin to wind..........you need to UNPLUG the foot control. So, in other words it to be used for sewing w/o a foot pedal. Now instead of doing as per instructions, assuming you've plugged everything in (foot pedal), after winding is finished just press the foot pedal and your off and running or sewing as the case may be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL.
please kindly rate the solution if it;s helpful,
take care.
Jun 06, 2010 | Brother CS6000i Computerized Sewing...
When I push the pressor foot down my machine flashes E1
Is the presser foot lever up or down? It should be down before you step on the foot controller or use the start/stop button.
For additional information, try this URL: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_cs6000btieus.html?reg=us&c=us&lang=en&prod=hf_cs6000btieus
Aug 24, 2009 | Brother CS6000i Computerized Sewing...
E1 error keeps coming up everytime I press the foot controller or start/stop button. Before this happened, the bobbin thread wasn't working. Only bunching lots of threads from top underneath cloth.
E1 means that the main motor is working to hard so the machine is keeping you from burning it up, make sure the handwheel feels smooth when turning if it doesnt clean your hook area and take the side cover off and make sure no thread is caught in the take-up lever
Jul 11, 2009 | Brother CS6000i Computerized Sewing...
Display shows E1
I think I have the solution, it happened to me.
The instructions for bobbin winding tell you to click the start button for the bobbin to wind. When you do that you get that E1 with a beeping. What they don't explain is that in order to press that "UP" arrow button to get the bobbin to wind..........you need to UNPLUG the foot control. So, in other words it to be used for sewing w/o a foot pedal. Now instead of doing as per instructions, assuming you've plugged everything in (foot pedal), after winding is finished just press the foot pedal and your off and running or sewing as the case may be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL. Hope this helps.
Aug 14, 2008 | Brother CS6000i Computerized Sewing...
E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Jun 16, 2006 | Kenmore 19233 Computerized Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
114 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
