Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Control panel in kenmore elite refrigerator goes off on on
The control panel goes off and on and I can't reset it without unplugging the unit. When it is off and I unplug it it comes back on and seems to work ok for a while then continues to turn it'self off and seemingly at random. When off the cooling in freezer and refrigerator both stop and everything warms.
  • 1 more comment
  • cschroeder Jan 18, 2009
    My 1 1/2 year old frig just started similar trouble. Control panel flashes and then cycles through all the settings, pauses then starts the routine all over again. In my case the teperature seems to be maintained.
  • jsw5150 Jan 31, 2009
    I am having the same problem. I unplugged and then plugged in the unit and seems to be OK, but this the first time. Everything inside has warmed up and the ice in the freezer melted!
  • Anonymous Apr 11, 2009
    My fridge keeps turning itself to the off setting. If I hit the temp button it turns back on for a couple of hours. My fridge is just 1.5 years old. Very frustrating.
  • 183 Answers
SOURCE: door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Posted on Aug 31, 2007
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
  • 67 Answers
SOURCE: Side by Side Kenmore Elite
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
  • 31 Answers
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
whytfang
  • 170 Answers
SOURCE: freezer is cold but refrigerator isn't
Number one when you can always provide model number and make...it helps enormously in troubleshooting otherwise you get these long detailed threads...from an anal tech like myself.
Cold is a relative term....how cold...use a thermometer...and determine if the freezer...is at least..10-20 degrees or colder if not it is not cold enough...and here are some generic answers for that problem....I will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the refrigerator side compartment..there is usually a baffle...that controls...the amount of air-flow into the frig side...it can be adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Apr 22, 2009
Had a power outage for a few seconds, the control panel is not working on my refrigerator, it reads er lf.
This error means some thing is wrong with the fan to the ice maker. It might also be a bad control board. If it is still under warranty get he board replaced. Kenmore has had some problems with these particular boards. You make be able to reset board by unplugging unit for a while and plugging it back in. Hope this helps
Jan 03, 2014 | Kenmore 31 cu. ft. French-Door Grab-N-Go...
The temperature settings for the refrigerator and
I have the same problem with this refrigerator. It looks like Sears Parts Direct sells all the parts for this unit except for the printed circuit board and temperature control switches. I called my local repairman and set up an appointment. He called back to cancel his appointment because he was also unable to get the electronics. Were you able to fix your unit? What did you replace?
Jul 28, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
My Kenmore Elite Smartwash control locked light went on after I finished a load. Now no buttons work. How do I unlock the controls?
Just remember, the instructions are printed near the button. This features locks and unlocks the control panel as a designed safety feature to prevent small children from manipulating the controls. In addition, if you get error codes, or the panel starts flashing or freezes up, sometimes these errors can be erroneous. Unplugging the unit for 30 minutes will reset the Central Control Unit (CCU). This is the main "brain" of the washer. Any error code following a computer reset, is usually a genuine problem. If you ever have questions about this washer in the future, please keep me in mind. Congrats on getting it working again!
Mar 03, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 546033 Side by side Control/Display panel dead
yes the only way is to repl the control board and make sure your outlet is properly grounded but you might wan t to unplug and plug it back to see if it resets but still it has to be repl ok
Jan 17, 2009 | Kenmore 54603 / 54606 Side by Side...
Control pad is flashing and can't seem to reset tempeature
try unplugging the unit and waiting 9 minutes then plugging it back in.
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite Trio
unplug the unit from the wall and re-plug it in and see if the display goes back to normal. It will stay that way untill the next defrost cycle and the code out again. Most likely there is a controller located on the right side of theevap that may need replacing. The code is saying there is a defrost problem.
Sep 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
313 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
