Question about GoVideo Go Video DVD/VCR Combo
Is a Go video DVR 5000 compatible with a new sony digital
On the back of the DVR 5000 it says analog, but not digital, is this unit compatible with new sony digital tv?
    New Friend:
I live in Australia and want see my cctv home in malaysia
Posted on Apr 29, 2013
Pavan
Posted on Dec 18, 2008
    Genius:
  • 1,199 Answers
Yes but you may need an adapter!
Posted on Dec 07, 2008
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
I need to know what model of a Motorola DVR is compatible with my receiver. What model can connect DIRECTLY from it's audio output to the audio input of my STA-795 Optimus Digital receiver (not through the...
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
Apr 21, 2011 | Optimus STA-795 Receiver
My Sony AV unit (probably 3 yrs old) suddenly switches from all 5 channels to just the two front without warning; I can push enough buttons to return it to all 5, but sometimes it switches back and forth...
You don't name the model but if there's asettign for audtomatically selecting digital vs analog when both are attached it's losing the digital signal and automatically switching to the analog feed. Find it in the manual. lacking a setting, it prefers digital over analog and will switch to analog on digital signal loss.
Analyze what source(s) are involved and investigate WHY you're losing the bitstream. Optical cables must be run with smooth loose bends so the light strength is not compromised.
Feb 04, 2011 | Sony A/V Receiver
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Jun 19, 2010 | Sherwood RV-4050R
Zone 2 will not play the dvr the dvr plays on the main zone other inputs play on zone 2
make sure you are using a parallel analog cable if you have it connected with HDMI or a Digital audio cable. Digital signals do not get passed to zone 2...make sure analog cable is to the right DVR input on the Denon.
Apr 10, 2009 | Denon AVR-2308CI
KDS-R60XBR2 No Analog Video
Hello.
The Digital video in this unit bypasses all the processing and is shot directly, so that narrows it down to the processing circuitry that the analog signals must pass through to get to the optical block.
The AU board in this unit has given me issues before, so it would be my first guess. It could be the UU or the B2, but the only bad one I've had with these boards was due to water damage, so I doubt that it is the problem.
The AU is located behind the UU (the one with all the connectors). Part number A-1217-798-A. Good luck.
Dec 29, 2008 | Sony KDS-R60XBR2 Television
No sound using digital coaxial connections
Couple of possibilities:
Press Audio Select on front of unit until "Analog" changes to "coax/opt"
or
When you select the component connected to the MULTI CH INPUT jacks as the input source (see page 38), this unit automatically
turns off the digital sound field processor, and you cannot select sound field programs.
May 16, 2008 | Yamaha HTR-6080
PS3 to XBR1 HDMI
hey, im hopeing the tech will be able to sort it out for you, theres not much any of us can tell you what he couldnt tell you tomorrow so be patient.
if he doesnt get it sorted drop us a comment and il try to help you.
Mar 23, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Tried to hook up our
It sounds like you need to switch back to the original input on the TV the one that you would have been playing your DVR through is receiving no signal therfor no prev. CH
Mar 08, 2008 | Televison & Video
GoVideo Go Video DVD/VCR Combo Logo
127 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
