Question about HP ScanJet 3500C Flatbed Scanner
HP scanjet 3500c and MAC OS 10.5.5 wont open
I get an "unexpected error" message when I try to open the application on my new computer running MAC OS 10.5.5. I reinstalled the software but get the same message. What can I do?
Dan123 sent me this link for the hp3500c driver (actually more than just a driver).
http://www.versiontracker.com/dyn/moreinfo/macosx/15999
. I am also running 10.5.5 and it works. It is a dmg file, so it's easy to install.
Posted on Dec 08, 2008
I have an hp scanjet 3570c but it doesn't work in mavericks what can i do?
Wow, those are some amazingly unhelpful posts.
The ScanJet 3570c is obsolete, you aren't going to find a driver from HP for Mac OS X 10.9 Mavericks, or likely anything after Mac OS X 10.4 Tiger.
That said, there is a third party solution, VueScan. Your scanner is supported, you can find more info here: http://www.hamrick.com/vuescan/hp_scanjet_3670c.html
Dec 31, 2013 | HP ScanJet 3500C Flatbed Scanner
My WeatherLink for Mac OS 10.5.8 was working fine until this morning. Then, I was unable to open and I got either of the following messages: java.lang.UnsatisfiedLinkError: /Applications/Mac OSX...
I was able to fix this problem on my system (running Mac OS 10.6.6) by setting WeatherLink.app to run in 32-bit mode. This setting is available in the info panel for the app.
Oct 23, 2010 | Ziff Davis Davis Instruments 6520C...
My cd will not install my hp c4200 printer on my mac. i get the message 'The application HPIO Trap Monitor quit unexpectedly. Mac OS X and other applications are not affected' Can you help.
I ran into the same problem. I updated the MAS OS using the automatic update feature. It uploaded updates for MAC as well as HP drivers. Problem was solved.
Mar 22, 2009 | HP Office Equipment & Supplies
HP scanjet 3500c wont open with MAC OS 10.5.5
I have a Mac running OS X 10.5.5. dan123 answered my hp3500c problem with the above link. I downloaded the dmg file and installed the hp environment and it works. I was not, however, able to use the Photoshop plugin in Photoshop Elements 6. I can use the hp GUI and name Photoshop Elements as the output. I performs the scan and then opens it in Photoshop.
Dec 07, 2008 | HP ScanJet 3500C Flatbed Scanner
Scanner not found
Macintosh: Scanning Software Does Not Open or Stops Responding in Mac OS X V10.4
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&dlc=en&cc=us&product=1138342&rule=15414&lang=en
The link will take you to the HP page where the handle for this problem is detailed. I did every step as listed and downloaded updated driver / software for the 4315. It works!
Aug 04, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
HP ScanJet 7650 asking for DPE
This problem happened to me to (OfficeJet 6310xi). These steps solved my problem:
When the program has the error, there's a button so you can show it where DPE is. Click the button
Navigate to Macintosh HD/Library/Application Support/Hewlett-Packard/HP Scan Pro/DPE/
Click on DPE 11.6.app
Then I could scan to pdf. When I upgraded to Leopard, I reinstalled my HP software, even though HP says it isn't totally compatible with leopard.
Nov 04, 2007 | HP ScanJet 7650 Flatbed Scanner
When we try to open dreamweaver it quits
It sounds like some components maybe missing or the application is corrupted. Try going into:
Hard drive/Applcations/Utilities/Disk Utility
You should see your hard drive on the left pane, select the volume under it, which usually is what youve named the drive or MACINTOSH HD if it hasn't been renamed. Select FIRST AID, then below select repair disk permissions. Restart the computer and try relaunching. If oyu still get the same "Unexpected quit" message, see if it gives you an error message code. If after you repair the permissions on your hard drive you still get the error, I'd uninstall and reinstall the OS, upgrade your OS X to the current 10.4.10...if the issue still occurs, your hard drive maybe failing.
Hope this helps.
Oct 20, 2007 | Apple iBook Mac Notebook
HP ScanJet 3500C Flatbed Scanner Logo
1,076 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
