Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I have a GE PSS26LSRB Profile side by side, the dispensor does not work, nor does the light come on. There are no lights in front working
  • mfreedman Dec 13, 2008
    Exact same probelm - different model
  • suzy2 Dec 16, 2008
    will make ice, just wont dispense it, the water will work most of time. but I noticed that the whole refrig will turn off it I push the Ice dispense button. the whole frig is two years old, GE profile ss/side by side
  • 34 Answers
My father's wouldn't work and here's what I did to fix...Good Luck!
Posted on Feb 20, 2012
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
  • 1314 Answers
SOURCE: GE Profile Ice maker/ Water Dispensor not working
ok try this for me and let me know how it works there is a water tank in the fridge and on installation you have to hold down the water for about 5mins to fill it up now the ice disp will be a separate issue hold my rating and let me know if your water flowes first
Posted on Jun 13, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Posted on Jul 23, 2009
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25QSTSS no lights working on the water and ice dispenser. No light working, no ice dispenses or water. Tried unpluggin no luck
I would remove the bottom kick panel ( 1 screw on each side ) and follow the wires to the receptical ( about 5 inches from bottom of door ) . Wiggle the receptical , to see if any of the dispensor lights come on . Also try pushing the wires into the receptical farther . If still no lights , then the main control board behind the refrig ( behind 8" X 10 " panel ) is probably bad . No communication between the main board and dispensor board . Part number WR55X10942 . I have yet to come across a bad dispensor board , so , replace the main board first . If the receptical process doesn't work .
Sep 18, 2009 | GE GSS25QSTSS Stainless Steel
I have a water softner in my house do I need the smart water filter on the refrigerator GE model PSS26NGSA GE PROFILE. I use the filter bypass plug but there is no water running thru the dispensor. Do I...
If your using the correct bypass plug which came with the refrigerator , the water dispensor should still work . Make sure the plug is very snuggly , tight in place .
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Location of condenser coils
They should be under the unit.
Nov 19, 2008 | Refrigerators
No power to the water dispensor or other buttons on the door
it has to be one of many things the Control Board or Double Outlet Water Valve,Dispenser Door Solenoid
Here to help
Nov 16, 2008 | GE GSS25JEMWW Side by Side
Ge fridg side by side with bottom drawer freezer
If you could give more information like will the water and ice work? If they do not I would replace the dispensor control bord. Also if you have the model with the thin doors there is a recall GE will only tell you about if you call with ice problem in the freezer door. Moisture leaks in and can also short out the control bord. So if you have frost building up at the ice chute I would 1-800-GE-CARES and find out if they will fix your problem. Good Luck
Jul 10, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
319 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
