Question about Tomtom ONE GPS Receiver
TomTom One screws
Wanting to open my tom tom one back but its not a torx screw. Its something different. Has a middle pen point. HEX 6 sides.
Inky
  • 691 Answers
SOURCE: TomTom 0ne
There are 4 screws:
1. Remove front bezel
2. unscrew 4 small screws (1 hole has anti tamper tape over)
3. remove "dome" rear of unit.
4. Remove 2 screws holding speaker in
5. Carefully remove all metal tape covering electronics
6. Remove 4 small screws securing PCB to unit
7. Remove 2 screws holding black plastic battery clip
8. Unplug small battery connector from PCB board.
9. remove battery and insert new one
Posted on Nov 09, 2007
SOURCE: My Tom Tom will not turn on
i have a tomtom go 510 and a ballpoint pen will not fit, i use a needle, i dont know if the 700 is the same but its worth a try.
Posted on Nov 14, 2007
  • 502 Answers
SOURCE: TomTom One repair
The only place I could find is this general GPS Repair Service that also takes care of TomTom.
Posted on Dec 21, 2008
  • 5 Answers
SOURCE: Cannot get into tomtom one v3
After the screws are out, just put something (I used a fingernail, but you might want to use something like a butterknife or a thin bladed screwdriver) between the silver front casing and the black back casing at the top front corner. Then gently pry until it separates. Do the same thing for the other top corner and the case should just pull loose. Be careful not to stress the cables connecting the speaker and the battery by pulling the back casing more than a few inches from the front casing (the battery and the speaker are attached to the back casing). The battery is held in place with sticky tape. Just disconnect the cable and gently pry it free from the sticky tape.
Posted on Mar 20, 2009
SOURCE: I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
Posted on Mar 31, 2009
Battery on my Tom Tom XXL540S is dead. How do I replace it. I can see no way to disassemble the unit.
Remove the two #5 torx screws under the label, using a butter knife or similar and starting near the screw hole side, slide the knife under the front bezel and pop it off the back. Push small white connector clamp towards ribbon cable on back half and the cable will slide out. The two halves are now separated. Remove three screws and remove circuit board. Wiggle and pull out the battery connector. Slide butter knife under battery and pry loose from the sticky tape.
Voids any warranty!
Mar 08, 2011 | Tomtom XXL 540S GPS Receiver
Tip
What type of Tamperproof Screw do I have TP3, Torx, Tri-Wing ?
Most of us know of the humble Flat-Head, Philips-Head, Pozidrive, Socket (Allen) and the now more widely used Torx Head as the most common type of screw head but what are the other types called and can you buy drivers to unfasten them ?
Here is a sample list of all those that you might come across
  1. Flat-Head (the most common)
  2. U-Shaped Head ( Flat-head with the middle missing)
  3. One-Way slotted (goes in with normal flat-head but can't be removed using a flat-head can come in Oval, Truss and Round)
  4. Philips (aka cross-head also very common)
  5. Frearson (similar to Philips with a narrower cross-head)
  6. Pozidrive (PZ similar to Philips but designed for more torque)
  7. Robertson (Square)
  8. Hex Socket (aka ALLEN Key)
  9. TORX ( 6-pointed star)
  10. TORX PLUS
  11. TTAP ( similar to standard TORX there drivers can be used to insert TORX screws but not the other way round)
  12. Torq-Set (similar to Philips but the four arms of the cross are offset with respect to each other so a Philips wont fit)
  13. Tri-Wing (aka Tri-Blade)
  14. Opsit (reverse threaded Tri-Wing)
  15. Spanner (Snake Eyes)
  16. XZN (Triple Square)
  17. Polydrive (Castled)
  18. Splinedrive (similar to TORX 12-pointed star)
  19. DoubleHex (similar to TORX 12-pointed star)
  20. Bristol (Castled similar to Polydrive used in Avionics)
  21. TP3 (Triangle Recess Pan Head)
There are also Security versions of numbers 2 (Secure-Philips) 5 (Secure-Torx) that have a Pin-head in the centre I am sure there are other Pin-Head versions as well
I had a AC transformer that had a triangular recessed screw head and I had already tried to use a Tri-Wing screw driver but I began to shred the wings and I just couldn't find the name of it eventually found it to be a TP3 Tamperproof Screw
http://www.tamperproof.com/categories/
All you need do click on the screw-heads and they will turn and open up the name and type of screw it is.
Finding a screw driver that will open a TP3 is difficult to say the least I have a minor look on ebay as this is a specialist screw type and expensive
Another difficult type to get hold of the the Tri-Wing or Tri-Blade now common on all game stations from the Nintendo GameBoy to the X-Box
on May 10, 2010 | Garden
How do I open the TOM TOM GO920 to change the battery?
You need to have a special tools!
Torx T7 and small flat head !
On the back of unit, using torx unscrew 2 screws!
Using small flat head screwdriver pick the front panel!
Carefully disconnect cables on the back of the display!
Unscrew circuit board!!!
Carefully disconnect speaker wire, and battery wire!!!!
Battery is glued to circuit board, carefully pill it off!!!!!!!
Place new battery on the same spot, and revert all the directions!!!!
Good Luck!!!!!!
Roman
Aug 12, 2009 | Tomtom GO 920 GPS Receiver
Tom tom 910
Stip down your tom tom unit, google for instructions and there is a set with pictures, But if not,
1, take the front screen surround off first, be gentle and prise it of with a flat screw driver, then unsrew the chassis from the plastic cover (4 x torx screws under the rubber feet)
2, unscrew the motherboards (torx again) and unclip the cable for the battery, and remore the eject mechanisum for the unit.
3 you may hadve to unscrew the harddrive and front screen if memory serves me well, but not to hard to do at all and my skills are basic but backed up by curiosity :o).
Jul 03, 2009 | Tomtom GO 910
Where blinker relay on the 97 Chevy blazer and what does it look like?
It's behind the panel to the left of the cigarette lighter. You need a Torx 25 screwdriver and another screwdriver for those hex shaped screws, forgot the size.
First unscrew the 2 Torx 25 screws beneath the steering wheel. Then unscrew the rest of those Hex screws on the bottom. The panels overlap, so be prepared for a lot of unscrewing.
You do need to unscrew the middle black panel on the bottom, right beneath the cig lighter. It's held by two Hex shaped screws, one on each side and are hard to unscrew. Also you need to remove your spare change sliding tray to unscrew the last hex looking screw.
Once you pop your panel off, the turn signal flasher is the right one. The Hazard flasher is the left one. You can find a replacement part at Auto zone. It's shaped like a cylinder with TWO prongs on it.
Good luck and hope this helps
May 02, 2009 | 1997 Chevrolet Blazer
Can not open it to change battery tomtom 1 3rd edition help pleast john
I take no responsibility if you damage your tt in this procedure.
To open the tt one third edition and change the battery you will need a # 8 and a # 6 torx bit. Remove the 4 # 8 torx screws on the back of your tt. After removing the screws carefully insert a guitar pic between the two halves starting at the top and continue around to the sides. Be careful so you don't damage the case. After you have gotten the three sides loose (top, right side, and left side gently pull the two halves apart from the top (be very careful at this point so you don't dislodge the USB port). Do NOT take it completely apart at this point because you have to remove the battery and speaker connections (they just pull out with a little wiggling motion). After you have taken the case apart and disconnected the battery and speaker cables you will need a # 6 torx to remove the board (don't skip this step because the battery is held in with two sided tape and you have to pry the battery out). Now that the board has been removed take a small screwdriver and pry up on the battery. Now all you have to do is reassemble your tt in the reverse order. Just remember the smaller screws are for the board
Mar 31, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom rider
I made a video on how it open your TomTom rider.
Feb 09, 2008 | Tomtom RIDER GPS Devices
Tom tom 300
you have te release the front cover. Then you see a couple of torx screws. Release them and the tomtom is open. You can change the battery
Jan 04, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
23 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
