Purple, green, red & blue outlines on Panasonic DLP PT-44LCX64
I get these outlines on my screen and I cannot get them to go away. I also have several bright spots on my screen.
  • 4 Answers
SOURCE: Panasonic PT-52LCX15 green spot on screen
Easy fix. I had the same green dot problem and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
JK
Posted on Dec 02, 2007
Luvlee
  • 59 Answers
SOURCE: Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Posted on Mar 23, 2008
albertv29
  • 87 Answers
SOURCE: Green and purple spots on my screen.
This unit requires the EEPROM correction tool Part # LSUQ0100.Only an authorized Panasonic service center will have this tool.
Posted on Jan 14, 2009
SOURCE: colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Posted on Apr 19, 2009
ArnelM
  • 184 Answers
SOURCE: some green spot, purple and red are showing on the tv screen
Try updating the software first :)
Posted on May 27, 2009
Panasonic DLP TV has huge yellow blotch covering most of the screen
SET uses a optical light engine--lamp which is quite hot shines into the engine---blue is first to get the light and heat and is usually first area in the lens and baffles to get damaged(loss of blue leaves red and green which equal a yellow screen.
You have a damaged light engine.
Apr 23, 2012 | Panasonic PT-43LCX64 43" HDTV
Blue outlines on screen. not a screen burn or convergence problem
I am not familiar with that particular model but most are similar.
It may need the blue focus adjusted. Most tv's have some type of automatic focus. If the blue is out of focus it can "bloom" beyond the red and green. There should be a focus block with 6 adjustments (2 rows of 3) behind the speaker cover. I wouldn't mess with the one labeled screen or block. Adjust very carefully. They are usually in the order Red-Green-Blue with the focus on the bottom row.
Mar 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
What is phosporing screen
The colored spots may be a light engine issue that Panasonic will pay for repair costs even though tv is few years old. Contact Panasonic. . No you can't reset the lamp timer without a remote.
Oct 11, 2009 | Panasonic PT-52LCX65 44" HDTV
Red tube out!!!!
Your TV is not DLP it is projection it has 3 tubes RED /GREEN /BLUE cost of new tube $500.00 used if you can find one maybe $100.00
Feb 28, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Pt-52lcx65 52 in.
call panasonic customer service....open a claim....problem is most likely that the eprom needs to be reflashed.....i contacted them several weeks ago, told them my problem which was 5 baseball sized colored spots, 1 red, 2 blue and 2 green. they had me perform a couple of tests using a dvd. when i reported the results they set up a service call with a local authorized repair shop. results were amazing. reflashing the eprom took about 4-6 minutes. in addition my brilliant color returned to the set as well as another problem of neon images going away. this was paid for by panasonic. my set was 2 years over warranty. panasonic has issued a service bulletin on this and are backing up these units.
pt-61lcx35
hope this helps, i am quite satisfied with what was done.
Dec 18, 2008 | Panasonic PT-52LCX65 44" HDTV
Help problems with Panasonic PT-47WX49
Can you post a picture of what your screen looks like and I will try an assist you with the problem.
Aug 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Red, purple and green dot
Its the light engine. Had a tehnician come and look at mine and was told it would have cost over $600 if I didnt have the warranty. Panasonic called 2 weeks later and told me that parts are no longer available for my model and are upgrading me to a 50 inch tv.(from 44 inch)
Nov 29, 2007 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
