Question about NetGear FE108 8-Port Ethernet Hub (FE108NAR)
Trying to connect two PC's to a Netgear FE108 switcher and a Thompson cable modem. Modem is connected to "Uplink" port on switcher. Normal/Uplink switch on switcher is set to "Uplink" Can connect one PC if I set IP address to "obtain IP address" but cannot get 2nd PC to connect. All are connected via RJ-45 cables. Do I need to assign IP addresses to both PC's? What default gateway do I use?
  • 3 Answers
Any network device, PC or otherwise, needs an IP address assigned. So, yes, both your PC's need an IP address.
Assuming your ISP lets you have multiple PC's(IP's) then you'll have to use the IP space provided by your ISP. The default gateway would also be provided by your ISP.
The way you SHOULD do this is to use a router, linksys for example. This way you can setup you private network(I.E. for example). This will hide and protect YOUR private space from would be hackers. The router would use the REAL IP address on the outbound side to talk to the cable/DSL modem. can use the ipconfig command at the command prompt(I.E. a DOS window) on your working machine to see the DHCP address and gateway that was assigned. Sound like your ISP only allows you one IP. The router solution above will fix that and let you connect as many as you want because the ISP will only see the one IP from the router.
Posted on Jan 08, 2009
Can i connect a netgear JFS524 directly to acable modem
Yes for sure you can do that.As the connector is RJ45.The only think is that for Thomson you need a cross-wired cable to connect to the netgear JFS524. If netgear do have Uplink port then you can use normal or straight through cable.For more infor Cross-wired cable are use to connect between network devices.
Feb 25, 2015 | NetGear ProSafe JFS524 24Port Ethernet...
Cannot connect to internet through netgear n300 wireless router
They are pretty straight forward. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Try resetting it by holding the reset in till it cycles through. This will clear all custom setting and try again.
I normally don't suggest firmware upgrades, but try updating. Defual login if you cleared custom is User: admin Password: admin
Other than that the unit is damaged / defective.
Oct 25, 2012 | NetGear N300 Wireless Router
I have d-link DIR600 router. When i am using my ethrnet cable to my pc it is working fine but when i am trying to use it with DIR 600 router it is not even detect internet connection
Most likely the cable modem is currently locked on the MAC address of the PC. Try the following:
  1. Power off the system, the power off the router (Unplug Power connection) and Unplug the Cable Modem power connection.
  2. Wait 3 minutes
  3. Power on the cable modem and let it completely reset.
  4. Power on the Router, making sure the cable modem is connected to the UPLINK port of the Router.
  5. Power on the system, making sure it is connected to any of ports 1 through 4
  6. Normally, this will resolve.
If issue persists, Right click the local area connection and Click REPAIR
Jun 20, 2011 | D-Link DIR-600 Router
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
DHCP problems for wired devices on my network
It sure sounds like the switch is not passing the DCHPDISCOVER packets through to the Apple Extreme.
Is the switch a NetGear Prosafe switch, or a GS608, or a different model?
If it's a managed switch (e.g. ProSafe) then you can connect to the switch's management UI and confirm that the default uplink port is set up for the port that connects to the Apple Extreme, and that it's set to forward DHCPDISCOVER packets to that port
If it's an unmanaged switch like the GS608, then it shouldn't matter which port you connect, but if your model has one port labeled "uplink" then you should be sure to use that port to connect to tha Apple Extreme.
One last thought -- have you replaced the cable that you're using between the switch and the Apple Extreme? You could test the network by first connecting your computer to the Extreme so it gets a valid lease, then unplug it and hook up the full network (computer -> switch -> Extreme) and see if you can still ping the router.
That's a bunch of thoughts, but may not be a solution yet. If these don't address the problem, post back with the model number of your Switch, and I'll go more in-depth.
Feb 12, 2010 | Apple Computers & Internet
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
Should be pretty simple ... power goes in a little round hole ... computers go into the various ports ... uplink goes to the modem.
Nothing called uplink? is there a switch on the back that makes port 1 or port 4 the uplink. Press it in (guessing) for uplink ... out for regular port. More likely you will have a dedicated "uplink"
Point is one of the ports goes to the modem ... if nothing is marked ... keep trying until you get connected.
You will need a short piece of Cat five wire to connect the router to the modem.
Oct 10, 2009 | Linksys WRT160N Wireless Router
Netgear FE108 connections
You must configure the other PCs in the same IP range of the netgear. fexample: if the netgear ip adress is then the other PC should have an IP like 10.0.0.x (x = any number from 2 to 254)
Sep 24, 2008 | NetGear FE108 8-Port Ethernet Hub...
Netgear FR114P with Netgear DS108 not working
DNeser, Port forwarding and static routes isn?t the route to go down to fix this issue. I have an FR114 in a similar configuration and yours should work as well. -When connecting a hub to a router you should be using a certified, standard Ethernet cable, not a crossover. Make sure it?s certified for at least 100 Mbps. -If you are using port 8 on the hub to connect to the router make sure the Normal/Uplink button is set to Normal. -Are the Link and 100 Mbps LED green on both the hub and router ports you use to connect? If not try a known good cable; if that doesn?t work try different ports. Let us know how things work out and please don?t forget to rate this post.
Feb 24, 2007 | NetGear FR114P Router
NetGear FE108 8-Port Ethernet Hub (FE108NAR) Logo
364 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
