Question about Sanyo DVW-6000 DVD Player/VCR
The open/close to open the disc tray will not work
I have installed new batteries in the remote but the disc tray will not open. Any suggestions?
Thank you, Susan Parrish, Benton KY
Sanyo Combo DVW 6000, purchased at Walmart on 4/6/2003,
Serial #30121199, Purchase price, $156.86.
    President:
  • 1,257 Answers
The most common is the tray servo is defective.  Second most common is the controller IC circuit is malfunctioning.
TRY THIS :
The motor that drives the tray mechanism may be faulty.
Try a reset: Unplug the units power cord for 30 minutes or more, then try it again.
If the reset does not solve the problem, it will need repairs.  If still under warranty you should take it in.
Posted on Dec 07, 2008
    Sergeant:
    Champion:
  • 304 Answers
Have you try to push the eject button on the player. if you have done this and the tray wont eject, there was a possible stuck disc on the tray. all you have to do is try to open the case and see and check for any possible stuck object inside
    Sergeant:
    Champion:
  • 201 Answers
Inside your dvd player theres a belt, it needs replacement, this should solve your problem
  • Sanyo Master
  • 13,433 Answers
Hey, the dvd drive is probably broken or stuck, do you hear a sound when you press eject? try turning the dvd off and try again, you can also try unpluging it for 5 minutes and try again.
  • 6,487 Answers
Try first to power off the device for about 5 minutes and then after that try to use again the remote to open the disc tray , if still not working make sure the battery if new on your remote...
Philips DVP5140/37 disc tray won't open. Hello! I have tried unplugging from the power source and waiting 10 seconds as their website says to do. I hold down the stop button on the remote 5 seconds...
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors.
If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
Nov 05, 2011 | Philips DVP5140/37 DVD Player
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
My dvd is not working on my blue ray it saying go to update some software
you will need to download the update from
http://pages.samsung.com/us/bluraysupport/support.html
how to - make an update CD
  1. Download the software update file for your hardware.
  2. If the update is compressed (zip file or rar file), the file should be uncompressed before burning.
  3. You must burn the update file on a blank CD-R/W disc by using "Burn Image" option.
  4. Burn an image file of the software update file (*.iso)
how to - update your player with your CD
  1. Press OPEN/CLOSE to open the disc tray.
  2. Insert the update CD-R disc with the software update, label facing up.
  3. Press OPEN/CLOSE to close the disc tray.
  4. Wait 1-2 minutes until the screen displays "Verifying Firmware version..."
  5. After checking old and new version, select "Yes" or "No" with "?" or "?"
    on the remote control. If you select "No", BD-P1200 will be powered off in a state of tray open.
  6. Press ENTER button on the remote control.
  7. Remove the update CD from the tray.
  8. Screen will display "Firmware Update Now Processing... Please do not turn off the power".
    This process will take 4-5 minutes. When done the screen and power will turn off automatically.
  9. Turn the unit on again with the power button. They tray will close automatically and a
    Menu Language Selection screen will open.
  10. Select the Language you want by pressing the corresponding number button.
  11. Update is complete.
Jan 15, 2011 | Samsung BD-P1500 Blu-Ray Player
How to open the DVD Player compartment door if the remote does not work?
There a button on the right side of the disc tray said open/close press this button ur disc tray will open manually.Press it again it will close.
Apr 27, 2010 | Televison & Video
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
My JVC DR-M70 dvd recorder tray won't close.
Sorry for the delay in following up. My tray problem appears to be resolved, but I wanted to wait a few days to see if the problem returned.
After reading several suggestions on various sites for other makes and models, I started experimenting to see if any would work on my machine. I made several failed attempts before hitting on the right sequence of steps. To the best of my memory, THIS is what finally worked for me:
1) I gently pushed the tray back to it's closed position (note: the solution did not work during previous attempts when I left the tray open)
2) I unplugged the machine for 30 seconds,
3) holding down the remote's open/close button, I plugged the machine back in and immediately pressed the stop button on the player, holding both buttons down for 30 seconds.
4) I unplugged the player AGAIN for 30 seconds, then plugged it back in.
A MIRACLE! Upon hitting the open/close button on the remote, this time the tray opened exactly as it should, and it's been behaving itself ever since. I don't know if any of the steps I performed were unneccesary. All I can tell you is that every time I left out a step, it failed. The first time I followed every step, I had success.
As for my remote: I put in fresh batteries. The open/close button still occasionally tells the tray to open and close simultaneously. tvdokter has suggested cleaning it on the inside, but unfortunately, I only see one screw (inside the battery compartment.) I can't see how to get in without breaking it. Oh well, at least I'm back to be able to play and record my dvds.
Anyway, thanks for the advice. I hope this solution will be helpful to someone else down the line. If anyone has any questions or comments, feel free.
Aug 27, 2009 | Televison & Video
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Sep 13, 2007 | Zenith DVD5201 Multi-disc DVD Player
Sanyo DVW-6000 DVD Player/VCR Logo
197 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
